Injector codes
Old Sep 17, 2022 | 04:32 PM
BWilcox's Avatar
BWilcox
it reads 0.00 when key off. Yes it reads OL when key on engine off and takes a second but fires up and runs while still reading OL I’m supposed to be reading the bottom pin closest to the drive side correct? I have a 4 pin ficm not 7 pin also
Old Sep 17, 2022 | 04:45 PM
bismic's Avatar
bismic
Doesn't whatever you are pulling codes with also retrieve the FICM voltage data from the PCM?
Old Sep 17, 2022 | 05:19 PM
BWilcox's Avatar
BWilcox
No it’s a really ****ty one and only reads codes and simple live data like temps and stuff. I put another ficm in that I know is good and not all the injectors are clicking and it still is reading OL
Old Sep 17, 2022 | 05:23 PM
bismic's Avatar
bismic
You really need ForScan or Torque Pro - $40 for Torque Pro, depending on the adapter, ForScan Lite can be had for around that also.
I do not understand why people struggle to troubleshoot these 6.0L's with poor diagnostic tools. It typically/quickly can cost them more than the tool.
Old Sep 17, 2022 | 05:31 PM
BWilcox's Avatar
BWilcox
Do I have to have a specific scanner to plug into or can I connect it the one I have?
Old Sep 17, 2022 | 05:34 PM
bismic's Avatar
bismic
They are downloads to smartphones. You then need a wireless adapter to communicate with the phone - WiFi or BlueTooth.
Windows laptops can run the full version of ForScan and a OBDII to USB adapter is needed for that.
Old Sep 17, 2022 | 05:44 PM
BWilcox's Avatar
BWilcox
I downloaded the app and it’s not telling me I can come t to the scanner I have. Maybe my local parts house will have one I can get
Old Sep 17, 2022 | 05:59 PM
BWilcox's Avatar
BWilcox
I called around and no one had it so I ordered it online it should be here Wednesday
Old Sep 17, 2022 | 06:02 PM
bismic's Avatar
bismic
The BAFX adapters are proven to work and are inexpensive
Old Sep 18, 2022 | 02:36 AM
BWilcox's Avatar
BWilcox
I replaced my ficm with one I know is good and it’s still reading OL and not wanting to even start my truck now it just cranks so could it be the wires that power the ficm? Or bad injectors? If anyone is a wiring diagram as to what wires power the ficm I can take a look and see if there good. So far I know it’s getting 12v to the ficm fuse but don’t know where to go from there.I’ve also got the FORScan coming in but it will be Wednesday before it gets here
Old Sep 18, 2022 | 08:05 AM
TooManyToys.'s Avatar
TooManyToys.
Old Sep 21, 2022 | 07:19 PM
BWilcox's Avatar
BWilcox
We’ll I got my ficm to 48 volts and it dropped to 47 and that’s as low as it goes but with the new ficm it’s not wanting to start
Old Sep 21, 2022 | 08:08 PM
  #28
xcrsp440's Avatar
xcrsp440
Use your scan tool to check the outputs that DTR shows you need.
Old Sep 23, 2022 | 09:39 PM
  #29
BWilcox's Avatar
BWilcox
So my FORScan finally came in. I got brand new batteries and hooked it all up and the truck cranks over but doesn’t want to start. I don’t hear all the injectors clicking but I’d guess at least 6-7 are. Here are the pressures of all the important things, I don’t see anything wrong with the pressures and I’m not sure why it’s not wanting to start now
Old Sep 23, 2022 | 10:19 PM
  #30
BWilcox's Avatar
BWilcox
@blicharski1989 @bismic i haven’t explored FORScan a ton, but can I kill individual injectors with this scanner?
