Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1974 f600 engine?
Old Sep 11, 2022 | 04:55 PM
Ram_Diesel_Power's Avatar
Ram_Diesel_Power
6th Gear
1974 f600 engine?
Hello I’m trying to figure out what motor I have in this 1974 f600. I was told it’s a 477 but it has a two barrel carb not a 4 barrel. I need a new carb. It is an old u haul truck.
Old Sep 11, 2022 | 06:21 PM
Ram_Diesel_Power
6th Gear
More pictures of my engine block
Old Sep 11, 2022 | 07:06 PM
85e150's Avatar
85e150
Welcome to FTE!
Did you just buy that that truck from someone in NH?
Copied from:
https://www.ford-trucks.com/forums/1...l#post20158669
F60KVU21209
F60 = F600 2WD gas
K = 477 4V Super Duty gas V8
V = Kentucky Truck Plant
U21209 = 1974 numerical series ( edit: April 1974 production)
212 = 212 inch wheelbase
No color code, usually this means the color is part of the special order. Red is always on the menu, so maybe this was some different shade of red when new.
F601 = F600 2WD gas, 17,000 lbs GVWR
4 8 = Standard cab, I do not have upholstery info
A = New Process model 435 four speed transmission
No rear axle code, see above, special order Rockwell (Timken) model F-106, 5.83 ratio, probably 15,000 lbs capacity
2 = Ford front axle, 5,500 lbs capacity, without power steering.
17000 = 17,000 lbs GVWR
870187
87 = Body Compay (Fire equipment etc) (EDIT: U-haul)
0187 = Special order number.
This is an oddball. A 477 with that low GVWR, saddled with a NP435, but the Bonneville 5.83 gear. Sold to a body company--- Does it have some special body or equipment?
That would make a good flat land light load flyer. If it's topping out at 40 MPH, something is wrong.
Does this decode match up with what you see in the truck?
Beware widowmaker wheels BTW.
It is the same truck.
https://cimg0.ibsrv.net/gimg/www.for...aa167715f.jpeg
All that said, your engine pictures are of an FT engine, a 330 or 361 2V. The Super Duty 401/477/534 were all 4 bbl carbs, and there are numerous other differences evident in pictures such as:
https://truckpartsinventory.com/parts/details/81496498
It could be an FE engine, based on looking at the exhaust manifolds. I need a side shot of the exhaust and a shot of the intake beside the carb to tell for sure on the FE vs. FT.
So....did you just buy this out of NH?
Old Sep 11, 2022 | 07:10 PM
85e150's Avatar
85e150
The casting numbers you posted--I can't make out the first digit.
I would be the year, followed by the month code, then the day, as explained here:
https://www.fordification.com/tech/datecodes.htm
EDIT:
Your other post seems to show "2M22", for 1972, December, 22nd day.
https://www.ford-trucks.com/forums/1...ification.html
Old Sep 11, 2022 | 07:17 PM
85e150's Avatar
85e150
OK so you're the 3rd guy decoding this truck.
Can you shed some light on that?
https://www.ford-trucks.com/forums/1...l#post20340658
Old Sep 11, 2022 | 08:44 PM
Ram_Diesel_Power
6th Gear
Engine
Yes the truck came from NH. It’s the same one. And it does look like 330. Not a 477. I’ll get some more pictures tomorrow. Also how do I reply to individual questions. There is no reply button Do I have to reply to the entire thread.
Old Sep 11, 2022 | 10:22 PM
Sport45's Avatar
Sport45
You can tap the “quote” button at the bottom of the post you wish to reply to. If you want to reply to several you can check the “multi quote” boxes of several and then the “quote” box of the last. Just insert your response after the respective closing [QUOTE]s.
Old Sep 12, 2022 | 08:41 AM
Ram_Diesel_Power
6th Gear
yes I just bought the truck. I plan on using it on the farm.
Old Sep 12, 2022 | 08:45 AM
Ram_Diesel_Power
6th Gear
Old Sep 13, 2022 | 10:26 AM
lunghd's Avatar
lunghd
You should send the motor and transmission to me right away. And the wheels. In fact - slap a stamp on the hood and mail everything to:....
Old Sep 26, 2022 | 07:11 AM
pfogle's Avatar
pfogle
Driver's side valve cover, there should be an engine identification sticker there. It looks like it's still intact, just covered in oil and muck. Wipe it off with a rag and see if you can still read it. That will tell you what the valve covers came off of, which will point you in the right direction.
Old Sep 26, 2022 | 04:31 PM
KiltedCannibal's Avatar
KiltedCannibal
3rd Gear
Those carbs are super easy to rebuild. Get the LIST number from the choke horn and call up Mike's Carburetor Parts.
Old Sep 27, 2022 | 08:22 PM
Destroked 450's Avatar
Destroked 450
It’s a 330 or 361 FT engine, commonly it would be a 330 in that light of a chassis but it has a reman replacement dated 4-85 so it could be either one,
only difference is the bore size
Last time I looked for a governor equipped Holley 2 bbl carb no one could get one, but a rebuild kit should be all it needs
with the governor disconnected I’d watch the rpm’s
Old Oct 6, 2022 | 05:10 AM
big job's Avatar
big job
My vote is a 330 either HD FT 2 barrel governed Holley dual thermostats dual fan belts FE style valve cover's.. The 401 477 & 534s big fat valve valve covers mechanical governor Not vacuum. Think it maybe another 'over time' who knows what was done. But being a former UHaul they were typical to have the 330 and strange tire sizes;;;
47flathead
1947 and Older Ford Trucks
Dec 31, 2021 11:58 AM
Mixer man
Nov 25, 2020 12:56 AM
arthall
Mar 7, 2020 10:17 AM
jonesa49f1
21
Jul 26, 2014 04:32 PM
51PanelMan
Mar 28, 2009 03:53 PM
