Ford F600 vin decode.
K = 477 4V Super Duty gas V8
V = Kentucky Truck Plant
U21209 = 1974 numerical series
212 = 212 inch wheelbase
No color code. Usually this means the color is a special order. U-haul? see below.
F601 = F600 gas 2WD, 17,000 lbs GVWR
4 8 = Standard cab. I do not have upholstery or seat info.
M = Clark model 285V five speed direct transmission
No rear axle code. Probably part of the special order
2 = Ford 5,500 lb capacity front axle without power steering
17000 = 17,000 lbs GVWR
870187
87 = body company
0187 = special order number
This is the second truck like this I can remember decoding recently. A real oddball. Is this a U-haul truck? A 477 Super Duty engine with a 17,000 GVWR. Usually you find a 330 FT engine in trucks with that GVWR.
Any questions or if something doesn't line up, let me know.
https://www.ford-trucks.com/forums/1...l#post20158669
