2011 - 2019 Explorer Discuss the 2011 to 2019 Explorer
Parasitic Drain
Old Sep 3, 2022 | 06:50 PM
Cparrish99's Avatar
Cparrish99
2nd Gear
Parasitic Drain
2118 Ford Explorer XLT. I'm trying to find the source of a parasitic drain. After following shutdown procedures, I pulled every fuse and relay in the distribution box and under the dash. It still has a 200 mA drain with no fuses in the boxes. I've checked the alternator and the diodes are fine. The only way to eliminate it is to disconnect the smaller cable off the positive battery post, which I assume feeds the computers. Any suggestions from the group?
Old Sep 7, 2022 | 12:43 PM
TJReams's Avatar
TJReams
Sorry I can't help you. However you already had a post for this problem on 9/01
TJ
Old Sep 12, 2022 | 06:09 AM
Bluehawk's Avatar
Bluehawk
A 200 mA drain isn't much. It could just be the computer. Chech your starter solenoid to make sure it isn't leaking power through the contacts. It might not be opening completely.
patphish
Feb 10, 2019 10:48 AM
strobewylan
Apr 16, 2017 09:54 PM
alhauger
Oct 16, 2016 08:12 PM
amos truckalot
Jun 29, 2010 07:57 AM
camperjill
Electrical Systems/Wiring
May 13, 2003 03:36 PM
