4r100
Old Sep 3, 2022 | 04:41 AM
valliant75's Avatar
valliant75
4wd High
Lightbulb 4r100
rebuildt 4r100 troubles
slow too engage revers,must give a litle throtle.strong in r when first engage sometimes also slow too disengage from reverse.
These symptoms are gone when pulls the conector too nthe solenoid pack.
worked for 1 week fine.
transgo shiftkit in it.
need tips,
Best regards Kjetil Sollid from Norway
Old Sep 3, 2022 | 08:32 PM
Listor's Avatar
Listor
need tips,
I can’t help you much on this but others might be able to , so a bump to take you back to the top!
Old Sep 4, 2022 | 04:20 AM
FinnishStroker's Avatar
FinnishStroker
Sounds electrical connection problem If pulling connector helps..
Clean connector and secure it with ziptie..?
Have you read codes from it?
If OD light is blinking,you have codes in it.
Generic scanners won't work.
ForScan APP and BAFX or OBDlink dongle,for example.
Slow engaging and disengaging,oil pressure issues..??
Just guessi'n,i'm no transmission guy..
@Mark Kovalsky transmission sensei
@helgaairhead Is located in Norway
Old Sep 4, 2022 | 07:49 AM
valliant75's Avatar
valliant75
4wd High
i hwent read codes,I hawe auto eugenity(from riff raff).
but when I mestre presure on it I got 100+psi at idle in all gears,exept r.when pull the pasienter side contact i got 100psi ther also.
i will read codes too night
Old Sep 4, 2022 | 08:15 AM
RacinJasonWV's Avatar
RacinJasonWV
I’ve been waiting on Mark to give you good advice, but while we wait…
Are you sure the shift linkage is adjusted correctly? (Probably yes since it works manually when removing connector)
Is the Neutral Safety Switch adjusted correctly?
Old Sep 4, 2022 | 08:24 AM
valliant75's Avatar
valliant75
4wd High
yes yes,I had the oil Pan off 3 times,checked ewerything,had the valvebody of,checked shiftkit again,check ***** etc etc
im suspecting solenoids ore wiring too it,but no od lamp blinks etc.worked perfekt for 1 week.mesuref presure is good with contact of i r
Old Sep 4, 2022 | 09:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think something is wrong inside the reverse clutch.
When you unplug the connector the pressure control solenoid goes to maximum pressure. All that additional pressure is why the problem doesn't happen with the connector removed. It isn't an electrical problem.
Old Sep 4, 2022 | 10:38 AM
callforfire's Avatar
callforfire
I was thinking over torqued feed bolts. If the case is distorted, fluid could be bypassing under the gasket. Doesn't it engage 3rd to get into reverse?
Old Sep 4, 2022 | 11:56 AM
Mark Kovalsky
It does not engage 3rd to get reverse. It does engage the direct clutch, which is also used in third gear. Maybe that's what you're trying to say.
Old Sep 4, 2022 | 12:00 PM
callforfire
Thank you, Yes. Something like that.
Old Sep 4, 2022 | 01:50 PM
valliant75's Avatar
valliant75
4wd High
my 3rd is strong and holds no mather how much im trying upp hill.ewen low clutch is ok on air test
Old Sep 6, 2022 | 04:35 AM
FordTruckNoob's Avatar
FordTruckNoob
Probably a dumb question but is your OD lamp working?
chrison600
Oct 11, 2012 08:27 PM
elotus
Aug 25, 2011 08:23 PM
charles.bunch
Mar 11, 2010 10:28 AM
jas88
18
Oct 4, 2008 04:50 PM
