E4od/4r100
Old Sep 2, 2022 | 06:40 AM
cyanide's Avatar
cyanide
E4od/4r100
Hey group I'm new here. I have an 1990 f250 with a 5.8 and a dump bed hope this is the right place for this.
I'm rebuilding the e4od tranny I have several parts trannies 1 of which is a diesel trans. I'm gonna use most those internals so my brother's don't destroy it again. Ok background info about 10 years ago i put a reman tranny in it, when i tore it down It has all 4r100 internals (some destroyed) snap ring groove blown off the end of the foward clutch and the stator support broken clean off. Any ideas on how this happened? Those aren't the normal weak points of the e4od or 4r100. So on to the build just gonna swap cases and put fresh rubber and paper in maybe a few bushings and or sprags. Low/rev clutch will have a six fiber/ steel stack with 6 pinion steel planets also plan to put 6 fiber steel in the direct clutch if I can find a snap to correct clearance which brings me to why I'm here I'm look n for the stack height clearances does any 1 here have those?
cyanide
All Things Towing
Sep 1, 2022 11:59 PM
Tbrooks26
Oct 7, 2017 07:41 PM
Norton72
Nov 13, 2008 12:23 AM
andy316
Oct 12, 2008 12:15 PM
oldogy
Apr 15, 2000 10:25 PM
