Sponsored by: Real Truck
Electrical issues
Old Aug 28, 2022 | 10:18 PM
not a ford guy's Avatar
not a ford guy
2nd Gear
Electrical issues
So I have an 03 F250 that is my Daly and I’m slowly rebuilding it everything’s been fine until fuse 35 kept popping now my windows don’t go down my gauges don’t work my automatic lights don’t work Now my cluster lights work in some of the lights on the cost to work but some don’t anyways wondering if anybody out there knows what could possibly be wrong somewhere in my right wiring it how would I go about fixing it thank you please help me
Old Aug 29, 2022 | 09:50 AM
udsuth78's Avatar
udsuth78
Sounds like you have a direct short. The fuse is listed as Gauge Cluster, Interior Lighting, and Battery Saver Relay. Any of those systems been worked on around the time these issues started? Any electrical work at all really, always possible you disturbed something by accident while working on something unrelated in the area. If you know your way around a multimeter you could start checking resistance to ground on the circuit. You will have continuity all the time but should see some resistance. With the meter hooked up you could try disconnecting things tied to the circuit and hopefully when you find whatever bulb or switch or ??? you'll see a corresponding change in the resistance. Another option is trying one of those cable trackers from Harbor Freight or wherever and try chasing it down that way.
Knucks
Sep 18, 2017 04:36 AM
ladelld33
13
Sep 21, 2016 10:50 AM
c delisio
Electrical Systems/Wiring
Feb 4, 2016 05:49 AM
ios1000
Sep 4, 2015 06:36 PM
Ranger-go-Boom
1983 - 2012 Ranger & B-Series
Nov 21, 2005 10:58 AM
