Instrument cluster/running lights out
Old Nov 13, 2005 | 10:50 AM
Ranger-go-Boom's Avatar
Ranger-go-Boom
Question Instrument cluster/running lights out
I have checked all the fuses and they seem to be fine, even the high voltage fuse under the hood. I thought it was the headlight switch and replaced it but the instrument lights and tail-running lights are still not working. Please anybody have the same problem? I need to go to work early AM and know I will get a ticket for no tail lights. I have Headlights,breaklights, turn signals, fourway flashers but the rest of the interior lights are gone. Please someone help
Last edited by Ranger-go-Boom; Nov 13, 2005 at 11:08 AM. Reason: I want it to be a question
Old Nov 13, 2005 | 11:14 AM
Ranger-go-Boom
I guess no one has any elcetrical problems with their Ranger. I must be the only one with this problem thats why it is not a topic anywhere. lol
Old Nov 13, 2005 | 11:19 AM
stan_02ranger's Avatar
stan_02ranger
I had all my instrument cluster lights go out, but all I had to do was replace the lamps, and I'm assuming you are certain that the lamps don't need replacing. I haven't experienced a problem like yours if its something other than the bulbs. Good luck finding the problem...those electrical gremlins can be tricky.
Old Nov 13, 2005 | 11:51 AM
RangerPilot's Avatar
RangerPilot
You checked all the fuses? That sure sounds like blown fuses to me.
You turned the interior brightness all the way up with the lights on didn't you?
All the taillight bulbs good?
Old Nov 13, 2005 | 01:37 PM
Ranger-go-Boom
I checked all the fuses twice, they are all good. I turned the brightness dimmer panel switch all the way up, still no lights. Bulbs are good to I checked them also. I am at my wits end. not sure if there is a relay switch for them that I am not finding? very strange because I had them three days ago. went to turn on the light switch and nothing. with the door open I do get lights on beep when in the parking lights selection though.
Old Nov 13, 2005 | 08:31 PM
Ken00's Avatar
Ken00
What year are we talking about?
Old Nov 13, 2005 | 08:56 PM
RangerPilot
Autozone will have wiring diagrams on their website, put in your truck and year and it will show you if there is a relay.
I would say try and see if those bulbs are getting power using a voltmeter.
Old Nov 19, 2005 | 11:20 PM
Ranger-go-Boom
very strange problem now. I replaced the headlight switch. But if the truck sits overnight the dashlights and tail lights wont work. But I warm the truck up for 15 minutes or so the dash lightsand tail lights come on Makes it a heck of a problem on winter mornings in the Pacific Northwest
Old Nov 19, 2005 | 11:22 PM
Ranger-go-Boom
Ken00, my truck is a 2000 ranger XLT 3.0Labout 70,000 miles
Old Nov 19, 2005 | 11:29 PM
RangerPilot
Well...I pose this to the more knowledgeble guys, does anything else normally come on around 15 minutes after the truck starts?
It just strikes me as odd, it comes on, works fine, but if the truck sits it goes off and has to almost "warm up" before it works. I would swear it was waiting for the temperature to come up if there was a way for that to work. Sorry just rambling.
Old Nov 20, 2005 | 04:09 PM
Ken00's Avatar
Ken00
The only thing I can think of that they have in common is the parking lamp relay.
Old Nov 21, 2005 | 10:29 AM
Batgeek's Avatar
Batgeek
My instrument lights went out once. Replaced all the bulbs and still nothing finally traced it down to the dimmer switch. A connection had broken inside and was keeping the panel lights from coming on but everything worked fine. I took the switch apart and soldered it back together been fine ever since. As for the whole heating and then working thing sounds like a connection. When metal in the connection heats up it expands and the circuit is closed and the lights work kind of thing. I’m just guessing here.
Old Nov 21, 2005 | 10:58 AM
87 XLT's Avatar
87 XLT
Does your truck have the lamps out warning indicator on the dash? If it does the lamps out module is probably the culprit.
Some guys have mentioned resoldering bad connections in the LOM.
jerrysrios
Electrical Systems/Wiring
91
Feb 18, 2025 03:12 PM
AaronEZ
Jun 23, 2022 06:44 PM
PowerStrokeJustice99
Jun 1, 2019 01:54 PM
gpeck
Modular V10 (6.8l)
Apr 9, 2015 02:53 PM
James Tuhill
Dec 13, 2013 01:29 PM
