Rough Idle, Hard start
Old Oct 16, 2022 | 04:39 PM
Will Henderson's Avatar
Will Henderson
Trailering
So from looking at it the IPR reads 55% at idle while the ICP read 600 psi
Old Oct 16, 2022 | 05:51 PM
Action4478's Avatar
Action4478
Warm engine or cold ? Either way it shows a high pressure oil leak or faulty reporting . 55% is almost max for the IPR at WOT . 600 ICP at Idle is close . Mine is about 585 or so ,IPR DC % 12.at Idle warm .
Old Oct 16, 2022 | 05:57 PM
Will Henderson
Trailering
It was cold idle because it won't idle once warm, after about 5-10 mins of idling it gets a lot rougher jumping about 100-150 rpm just trying to stay running
Old Oct 16, 2022 | 06:19 PM
Will Henderson
Trailering
faulty reporting may be a cause but I don't think so because it started out at 15% then it went to 25% then 40% and finally 55% this was all within about 25-40 seconds
Old Oct 16, 2022 | 06:22 PM
Action4478's Avatar
Action4478
On mine KOEO IPR DC% is zero . The IPR only does what it is asked for based on what the ICP reports to the PCM . 15 % engine off is false .
Old Oct 16, 2022 | 06:27 PM
Will Henderson
Trailering
On mine KOEO IPR DC% is zero . The IPR only does what it is asked for. 15 % engine off is false .
so what does that mean for mine when it says 15% when the engine is off? Could it be a possible electrical issue or maybe it is false reporting
Old Oct 16, 2022 | 06:35 PM
Action4478's Avatar
Action4478
The engine cannot run without correct info from the sensors . On yours , the PCM says IPR is 15% when not running . It either sees that (key on) from the ICP sensor or the PCM is screwed up . I have never seen this one before . The IPR is not a sensor . The IPR DC is what the PCM is telling it to do .
Old Oct 16, 2022 | 06:39 PM
Will Henderson
Trailering
It also looks like my ICP is reading .2V KOEO. looking it up it seems it should read .02V KOEO (does that sound correct?) .
Old Oct 16, 2022 | 06:43 PM
Action4478's Avatar
Action4478
Mine is 0.20
Old Oct 16, 2022 | 06:44 PM
Will Henderson
Trailering
ok so I guess that seems to be right
Old Oct 16, 2022 | 06:51 PM
Action4478's Avatar
Action4478
I follow so many of these no start threads I cannot remember if you changed your oil or not .
Old Oct 16, 2022 | 06:55 PM
Will Henderson
Trailering
I changed my oil I use 15w-40
Old Oct 16, 2022 | 07:00 PM
  #28
Will Henderson
Trailering
What's the difference between my oil being changed and it not being changed? ( I understand it's a heui and mostly understand how that works and the significance of the oil, I'm just curious)
Old Oct 16, 2022 | 07:08 PM
  #29
Action4478's Avatar
Action4478
Old oil is thinner from fuel and combustion contamination . Nature of the engine running at 400 LBS of compression per Cyl . ( fuel getting past the rings ) If its thinner all the time it can cause symptoms of HP oil leaks to be compounded .
Old Oct 16, 2022 | 07:10 PM
  #30
Will Henderson
Trailering
Thank you for the explanation, that makes sense. I think I've only driven about 40 miles on the new oil and I got a oil analysis done and it found virtually no fuel in the old oil
Will Henderson
Aug 25, 2022 10:31 PM
skywurz
Feb 26, 2015 09:42 PM
dougx75
Aug 16, 2009 07:23 PM
grumy oldman
1997 - 2003 F150
May 1, 2007 03:09 PM
