new to fte, I have 97 f150 I just bought 2 weeks ago and already had to put a cam sensor in,the problem I have now is a rough ilde and misfireing.no codes have been set
Changed fuel filter,coil pack,plugs,wires,and no change. Today I try to start the truck and it would not start. crank a couple of times seems to have compression lock ,pull the plugs found them wet,smells like dexcool antifreeze.I decide to check oil,pull the dip stick oil level fine,removed oil cap,found antifreeze on the cap and in the filler neck.I guess I have a couple of blown head gaskets
I had to sent it back to the dealership today,seems they put in a bad cam sensor and they found the intakes leaking , thanks for the help. I work with heavy equipment that dose not have a lot electronicis
