problem timing pick pip sensor replacement.
Old Aug 25, 2022 | 12:39 AM
Nonofordf150's Avatar
Nonofordf150
I replaced my pip sensor, before dismantling I made sublon distributor brands, and when reassembling I can't get back exactly on my tracks, I'm slightly off.
so I think the pinion during assembly must have been slightly shifted.
so instead of being at 10 btc as before dismantling, I found myself at 8 btc after reassembly.
it's serious or I just have to adjust it to 10 btc?
Old Aug 25, 2022 | 06:28 AM
rla2005's Avatar
rla2005
Adjust the base timing and be done with it. It's not serious but it would behoove you to adjust to the factory setting or a few degrees more if you want to try a few more degrees like many have done.
Old Aug 25, 2022 | 11:26 AM
Nonofordf150
I think it was already disassembled because the marks do not look original.
I put my timing back to 10 btc I'll leave as.
Thanks for your answer, that's really cool.
Old Aug 25, 2022 | 01:27 PM
Nonofordf150
Old Aug 25, 2022 | 01:30 PM
Nonofordf150
here is a photo of min distributor settled.
compare to other photos my thread 1 and more to the right, while some photos seem to be more to the left of the admissions.
but if that is nothing, so much the better.
Old Aug 25, 2022 | 02:43 PM
rla2005's Avatar
rla2005
Looks like the distributor may be stabbed one tooth off. Not a big deal.
Old Aug 25, 2022 | 03:46 PM
Nonofordf150
okay it works well even if it's not serious I prefer to put it back like the original so I think to put it back a tooth less to be sure.
Taxer
3.7, 3.5 and 3.0 Duratec V6
Jan 23, 2021 09:46 PM
abyars111
Nov 4, 2013 07:19 PM
NiccoHel
1978 - 1996 Big Bronco
Oct 3, 2011 12:28 AM
cclarkF800
Mar 30, 2006 06:59 PM
phoneman91
Mar 25, 2006 05:07 PM
