Knock Sensor--range of adjustment?
Old Mar 25, 2006 | 03:30 AM
phoneman91's Avatar
phoneman91
How many degrees of timing will the knock sensor on a 92 5.0 adjust out of the total timing advance??
Old Mar 25, 2006 | 05:13 AM
LindenBruce's Avatar
LindenBruce
I'm not sure how far it will retard the timing. I presume far enough to correct the detected pre-ignition. I know the sensitivity of the sensor is a factor of the torque applied when installing the sensor in the engine. The tighter it is the more sensitive it will be and detect pre-ignition earlier and retard the timing. Torque the sensor to the minimun setting if there is one. You could even try using teflon tape on the threads to help minimize sensitivity. Hope this helps.
Old Mar 25, 2006 | 05:07 PM
EPNCSU2006's Avatar
EPNCSU2006
I want to say it will pull about 4 degrees advance when knock is sensed, but I'm not sure.
