I'm going to just replace it. If I jack with it the oil pressure shoots up for a split sec and almost starts. That's new. The plug doesn't feel like it's connecting to anything it just falls in the port. Feels like when you put a fuse in a dead slot. But the gauge test shows everything is connecting right?
It should have a little metal clip that snaps in place and holds it in.
It seem like everything is reading like it should. Kind of hard to guess over just a picture. But when cranking ipr% should climb up in % as your cranking and icp should build pressure as your cranking. Takes around 500 psi before injector fires.
Ya its msking good condition. Well I'm ordering a oem ipr. It will be a couple days I'll let yall know how it goes. I want to think everyone that has helped me. A couple weeks ago I never even heard of an ipr icp hpop. I'm getting a crash course on this 7.3
Warning, there’s a lot of fakes floating around on Amazon and eBay. Only order from a reputable source.
Be sure to check the IPR wiring as well. Pull the loom and check back a good ways.
A very common problem with our trucks is a short in the wiring to the IPR valve. I've had it happen to me also back when I first got my 7.3 and knew nothing about how everything worked let alone how it all worked together. It kicked my *** for months and cost me a good bit of $$. Anyway back to the point, the insulation will actually turn to putty or something inside the harness. I'd guess it gets saturated w/ oil from all the years of service and just deteriorates. It usually starts as an idle dip, then occasionally will randomly stall , sometimes it won't restart for hours then fires off like nothing happened. If this is your problem it sounds like it's in the latter stages and wiggling the connector makes contact for short blips. I would open the harness and inspect the wires for a good 8-10 inches if you can. If you do have a short it would likely be pretty easy to spot once you get all the loom and tape out of the way.
Dammit Jason beat me to the wiring harness, that'll teach me for laying out a saga instead of short and sweet.
It was just that I only had time for the short cliff notes version. Your’s is much more thorough. (BTW posts popping up while I’m writing a reply happens to me all the time too)
I just put 12 volts on the ipr and she fired up. Do you think that sounds like a wiring issue or bad ipr?
I would guess the wiring but that’s just a guess. My thinking is the PCM should already be commanding the needed voltage, so running with direct power points to wiring. But I’m not sure the IPR is a 12v solenoid. It may only see 5v max from the PCM (don’t remember) in which case you’ve now added more than normal and potentially “pushed” a bad IPR into functioning.
Either way the wiring should be confirmed as next step before buying parts.
Wiring, IPR works when it gets voltage. You can check the voltage in the connector. The red wire should show battery voltage at all times while the ignition is on. The PCM controls the valve w/ the ground side of the circuit. The quickest though is to just open the harness and have a look.
Well I already have ipr coming tomorrow. Do I'm going to put thst on. Im going to check the wires rn. So if the wires look good and the new ipr dont fix it. Bad pcm?
Bad PCM doesn't seem likely. The IPR DC% numbers climb when cranking the engine don't they? That means the PCM is asking for more hpo, but that pid doesn't tell us if the signal is received only that it was sent. All the signs are pointing to either a wiring short or bad connector.
Yall are freaking awesome. I bought this truck as the ppl was pulling parts off getting ready to part it out. Idk much about diesels but I have heard everyone all my life saying the 7.3 was a great engine so I had a feeling it still had life in her.
The funny thing is the ipr was the first thing I looked at But it looked new and the ppl said they threw all kinds of parts at it. So my head said of course it's not going to be that ez and moved on and replaced everything else. Without yall pointing me back to the ipr she would have been scrap. Yall saved a 7.3 and gave a poor boy his first diesel. Thank you to everyone. I know some of you put some real time into helping me and I really appreciate it.
Just a word of caution going forward, the 7.3L is notoriously picky about only using Motorcraft or International sensors and vavles like CPS, ICP, IPR, etc. If you need to get an aftermarket sensor to get back on the road, go for it. Just know that the 7.3L may be upset about it at some point in the future.
