Turn signals not working
Old Aug 24, 2022 | 12:11 AM
Eric1109's Avatar
Eric1109
So I installed a performance world 329021 harness and a ididit style column. For some reason indicators don’t work. I did a continuity check on wires starting inside column at the switch all way to front and rear wires. Continuity is good. I checked the fuse as well as I tested the flashing module by removing it and wiring a bulb directly to it. It worked. So when I put ignition on nothing happens. I put a volt meter on turn signal wire at end and nothing. I also don’t hear flasher working. So no clue as to what’s going on.
Old Aug 24, 2022 | 04:58 AM
Board4RD's Avatar
Board4RD
Are you by chance testing with an incandescent bulb and have LED in the system? Could be you need to replace the flasher with one designed for LED.
Old Aug 24, 2022 | 08:48 AM
Eric1109's Avatar
Eric1109
Unfortunately no. Regular bulbs.
i am totally stumped. Performance world won’t provide technical help. Fair enough they would be spending their whole time trying to sort out wiring issues.
Old Aug 24, 2022 | 09:25 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Continuity obviously only tells you the wire is not broken, which on a new harness should not be an issue. You said you checked for voltage on the end of the wire and found none, I'm assuming you mean the bulb end, there again that does not tell you much. You need to verify you have power coming into the turn signal switch and trace the power through the switch. If your using a standard flasher it is usually wired into the power lead and breaks(flashes) the circuit with a bi-metal switch, that way it can work both sides with a single flasher. A simple test light is the easiest way for troubleshooting this issue.
Let us know what you find and Good Luck.
Old Aug 24, 2022 | 11:15 AM
Bob Ingram's Avatar
Bob Ingram
Do you have the wiring diagram?
Old Aug 24, 2022 | 11:39 AM
CharlieLed's Avatar
CharlieLed
As a follow on to truckemtnfords comment...do you have brake lights? If not, then your problem lies in that circuit...the flasher opens and closes the circuit to the brake light so if there is no brake light then there can be no turn signal. Good luck....
Old Aug 24, 2022 | 11:40 AM
Eric1109's Avatar
Eric1109
I think I need your explanation dumbed down. Step by step.
whhat I did do is I checked that I had power going into column switch. I do it’s fed by gm connector Wire k. So wires are intact and power going through to steering column. Could it be the flasher unit in the fuse box even though I seemed to get them to work when independently tested.
what else should I try. Please simple directions. Thank you
Old Aug 24, 2022 | 11:42 AM
Eric1109's Avatar
Eric1109
No brake lights either. Seems nothing going to column works. Including horn.
Old Aug 24, 2022 | 01:44 PM
Eric1109's Avatar
Eric1109
Just noticed that when power is on and I apply brakes it blows brake fuse. So are all indicators front and rear tied somehow to brake lights.
Old Aug 24, 2022 | 10:16 PM
truckeemtnfords
If your blowing fuses when applying the brake pedal something is grounded. Double and triple check the wiring and light sockets.
Old Aug 24, 2022 | 10:54 PM
Eric1109's Avatar
Eric1109
I think I sorted one thing. I had my brake switch power on one post and ground on other so when I applied brake it opened circuit and shorted because was grounded to frame. Now have return wire to column
question. I have is with gm column connector. Reading few different things. I seem to have constant power to k. Which seems right as those are hazard. However I don’t seem to have switched power to L which is turn signal switch. Should there be power to that
Old Aug 25, 2022 | 08:54 AM
truckeemtnfords
Yes, turn signals need keyed power. Brake lights can be either keyed or constant, it varies by vehicle and manufacturer, I prefer keyed. You wired it so you have your choice.
sign_man
Nov 6, 2012 03:56 PM
78bigunns
Electrical Systems/Wiring
19
Dec 7, 2005 02:43 AM
RFT
Oct 27, 2004 05:19 PM
sullivas
Dec 16, 2003 12:25 AM
zauss
Nov 13, 2003 02:07 AM
