TIME SENSTITIVE 302 Swap!
Old Aug 23, 2022 | 05:05 PM
fordifictor's Avatar
fordifictor
Hey Folks, I’m not an expert and I need help, My engine is shot on my ‘60 f250 4x4 (292 v8) and I was wondering if the Warner t-98a transmission will fit an ‘85 302 small block without any adjustments. I need to know as soon as possible, very time sensitive as I have I have a motor lined up to buy. Just need to know if the bell housing will line up, or if I need to do something to get it to.
Old Aug 23, 2022 | 05:25 PM
85e150's Avatar
85e150
No.
A T98 will have the "square" transmission to bell pattern.
The 302 will use a bell with the more rectangular "butterfly" pattern.
Your bell incorporates the rear engine/transmission mounts doesn't it?
And your front mount is under the crank off the front cover?
A 302 requires multiple adjustments.
Quickest solution here is another 292.
Old Aug 23, 2022 | 07:17 PM
fordifictor
Originally Posted by 85e150
No.
guess I’ll have to do that then. You know where I might find another 292? Or a new block for mine?
Old Aug 23, 2022 | 07:49 PM
85e150's Avatar
85e150
Is your block ruined or overbored already?
There are some tips and links here, and the next link is to a supplier mentioned in that thread:
https://www.ford-trucks.com/forums/1...r-vendors.html
https://www.sandjengines.com/searchp...~~~4.8~~~~~~/1
You can take you chances search out a used engine also.
Old Aug 23, 2022 | 10:00 PM
fordifictor
I found a hole in the block on the side
Old Aug 24, 2022 | 09:32 AM
Byrd.Dog's Avatar
Byrd.Dog
Could always cut out the stock trans crossmember & fab up a custom one to use a C6 or T5 behind the 302. I did this to swap from the 292/T98 to a 400/C6. Engine mounts were a little difficult, but the trans crossmember was fairly straightforward. Alternately, I still have the old 292 out of mine. It's been sitting on a stand for several years, but was running when I pulled it. If you're not too far away, it might work out.
Old Aug 24, 2022 | 06:05 PM
fordifictor
I’m down in Naples FL, where are you?
Old Aug 25, 2022 | 08:18 AM
Byrd.Dog's Avatar
Byrd.Dog
Yeah..... probably not going to work - I'm in Amarillo TX.
Old Aug 26, 2022 | 06:43 AM
fordifictor
Oh well, I have what I believe to be a working Lincoln 317 y block, I'm pretty sure those swap right in. Just have to get it started. I tried hooking some wires up to it but I'm sure I did something wrong. Got spark on the battery though
SIXTFOR
Oct 10, 2021 04:18 PM
SkylarkTed
Apr 21, 2021 11:45 AM
uncleshepard's69
Oct 28, 2010 06:58 PM
hypetyme
Dec 6, 2009 06:11 AM
red59
Engine Swaps
May 10, 2004 11:16 PM
