Engine Swap
Old Oct 26, 2010 | 08:37 AM
uncleshepard's69's Avatar
uncleshepard's69
Engine Swap
Does anybody know if a 302 motor out of a 1976 ford granada will bolt up to my 1969 f 100 three speeed transmission. Thanks for the Help everybody! Sorry there is a 240 i6 in there right now what do i need to do to get it to mate up?
Last edited by uncleshepard's69; Oct 27, 2010 at 01:32 PM. Reason: Added motor size
Old Oct 26, 2010 | 12:18 PM
jowilker's Avatar
jowilker
You didn't say what engine is in there now, 302 yes, I6 using 302 perches yes, FE 360 no, not without 302 bell. The engine itself will fit, mating is the concern.
John
Old Oct 27, 2010 | 01:29 PM
uncleshepard's69
Sorry there is a 240 in there right now. What all do i need to do to get it to mate up?
Old Oct 27, 2010 | 02:24 PM
hotrodfordpickup's Avatar
hotrodfordpickup
The 240 is a ok. motor..If you not going to hotrod around the 240s a pretty good old motor..I put lots of miles on those old things..They were pretty good on gas If you want to go to the 302 your going to need the bell housing and flywheel moter mounts maybe to clutch too..But theres a lot 302 stuff around..easy to find..bill
Old Oct 27, 2010 | 05:54 PM
jowilker's Avatar
jowilker
The 302 uses different engine perches from the 240. The tranny bell is the same, you will need correct flywheel & clutch for the year correct 302.
Shouldn't be a major deal to make the swap.
John
Old Oct 28, 2010 | 06:58 PM
312's Avatar
312
and 302 truck motor mounts as well as the perches.very easy swap.you will need the early 302 flywheel made before 81.
filthy pride
73
May 7, 2009 06:37 AM
HookedOnFuel
34
Jun 8, 2008 08:09 AM
mjas2992
New Jersey Chapter
Sep 26, 2006 07:19 PM
RonK
1983 - 2012 Ranger & B-Series
Apr 25, 2006 10:39 PM
77fordf250
Jan 8, 2002 08:15 AM
