Dumb question for you all but where is the temperature sensor located on a 360 FE? My gauge reads cold all the time and id love to ground the plug to test the gauge, and replace the sender if needed. Driving around with no temperature reading is probably not a great idea. Thanks!
The hole right under the C9AE 9425B is where mine was. I moved it on this intake to the thermostat housing because the engine has a HEI distributor and it wouldnt clear the sensor.
