which is which?
i want to replace my temp sending unit and i know where it is. its right next engine coolant temp. sensor. i found the 2 sensors but which sensor is which? one has a brown connector and is front of the other.
Also, as far as troubleshooting a temp gauge reading incorrect, would it be safe to switch the connectors in order to check the temp gauge and associated wiring? i noticed that both connector are 2-pin connectors but i haven't looked too much past that.
Thanks for any help
Guy
The sender for the gauge only has one wire, the sender for the powertrain control module has two wires.
The gauge reading "incorrect" really means nothing. None of the gauges are accurate to begin with.
What makes you think the gauge is going bad? A quick way to check the gauge is to ground out the sender wire. If the gauge spikes to it's max reading, the gauge is fine. Why do you think the sender is out?
When i say the gauge is inaccurate what i mean is that the gauge reads cold (below the "Cold" line) after a 35 mile trip yet the A/C blows hot air. the Gauge used to display operating temp (the middle of the gauge's range) after only 3 miles of driving at the most.
The gauge is the factory gauge not aftermarket.
if the sensor connector has two pins can i jump the connector and get the same result as grounding a single wire sensor? Though i would still like to try switching the connectors if i can do so without causing any damage.
Thanks for reading, advice is welcomed
Guy
Good luck.
