injectors missing when warm
Old Aug 18, 2022 | 04:32 PM
ballbandit's Avatar
ballbandit
03 6.0. injectors was leaking fuel in pan. put new injectors in with fresh oil. truck runs fine when code injectors fire right. gets warm 5 miss. I changed 2 on right side again just to see. still does same thing. every now and then different injectors show up. I swapped ficm with another one no change. swapped injector harness no change. ipr is 21%. icp is 640. fuel pressure 60 psi. no programmer on it. no smoke out pipe.ficm voltage 48v.
Old Aug 18, 2022 | 04:45 PM
bismic's Avatar
bismic
Same '03?
https://www.ford-trucks.com/forums/1...ing-6-0-a.html
Old Aug 19, 2022 | 04:59 AM
ballbandit's Avatar
ballbandit
Originally Posted by bismic
no different one
Old Aug 19, 2022 | 02:57 PM
bismic's Avatar
bismic
After changing them out, did you ever see a repeat code for either of the two injectors you changed out?
Old Aug 20, 2022 | 07:50 AM
ballbandit's Avatar
ballbandit
wasn't code could see them missing on computer. but no change after changing them. now code for number 6 is showing up. sometimes 8 will be missing along with 3. I'm thinking it's not the injectors. gonna try another icp and ipr. wondering if maybe it's the cam or crank sensor fishy. no codes for them but I'm not afraid to try different ones. I would think if it was injectors would do it all the time. it's perfect cold.
Old Aug 20, 2022 | 08:18 AM
bismic's Avatar
bismic
Still might be the injectors. Where did you purchase them from?
My point in the question about the codes was mainly if you saw issues with the two injectors that you recently installed. Clearly you saw issues with the previous injectors in those cylinders - enough so that you replaced them. So have those observed issues repeated themselves on those two newly installed injectors - after replacement? I know you said "no change" in the post above, but I just didn't know what that meant specifically.
Now that you have a code, please post the code number, or at least tell us if it is electrical or contribution.
Which two injectors did you recently change.....not #3 was it?
Is it a contribution test (power balance test) that you are doing, or a relative compression test? Do you have IDS?
Old Aug 20, 2022 | 11:20 AM
ballbandit's Avatar
ballbandit
it's cyclinder 6 contribution. injectors came from pennsacola diesel. I m using a snap on solus pro scanner. gonna get back on it and look at more stuff when cold the compare when hot. thanks for replying
Old Aug 20, 2022 | 04:08 PM
Hartwig's Avatar
Hartwig
pennsacola diesel.
Aaaaaa....
https://www.ford-trucks.com/forums/1703027-starter-issues-tipps-for-roadside-fix.html
I also thought they sell original parts
Old Aug 20, 2022 | 04:26 PM
bismic's Avatar
bismic
After seeing Pensacola, I figure I need to bow out. They just have so many issues and I have nothing good to say about them.
Old Aug 20, 2022 | 04:46 PM
Hartwig's Avatar
Hartwig
If you want, try to get a statement from them.
Maybe they will answer you.
Unfortunately, I have not received a reply.
Old Aug 21, 2022 | 07:49 AM
ballbandit's Avatar
ballbandit
thats nice to know. ugh
85Supclub
Aug 12, 2025 04:58 PM
speakerfritz
Nov 27, 2016 04:32 PM
vermilian
Nov 12, 2014 12:03 PM
TN97STROKE
Apr 29, 2008 04:46 PM
atving2
Apr 9, 2003 10:17 PM
