Time to change trans fluid
Old Aug 16, 2022 | 06:39 PM
jimzpsd's Avatar
jimzpsd
Assuming its a simple drain, new filter, gasket, etc. I've done this on my previous truck ('97 F-350 E4OD) many times and I was also able to drain the torque converter as well. Same thing or is it different? Looking for tips like other drain points or service. Truck in question is a 2017 F-350, thanks.
Old Aug 16, 2022 | 06:56 PM
FishOnOne's Avatar
FishOnOne
It's an easy job and the gasket is reusable. No way to drain the torque converter. I recently did mine and was surprised (or maybe I shouldn't have) how expensive the Motorcraft LV fluid is.
Old Aug 16, 2022 | 07:20 PM
jimzpsd's Avatar
jimzpsd
True, its not cheap fluid. I saw this video too and there was one where a guy also flushed out the cooler and lines. I don't think I'll take it that far...just the basics is fine. Thank you
Old Aug 16, 2022 | 07:36 PM
FishOnOne's Avatar
FishOnOne
Yes there's a method to flush out the lines and cooler etc, but you'll need extra transmission fluid to support that process and I don't think it's really necessary.
pbrogan
Sep 10, 2015 05:46 PM
jaagen
Nov 23, 2012 01:36 PM
bengerman
May 15, 2012 11:16 PM
tobyw
Jul 10, 2007 05:52 PM
hotrodford_88
Mar 30, 2001 07:19 AM
