trans fluid change question
Old Nov 22, 2012 | 09:22 PM
jaagen's Avatar
jaagen
As of late I've read a few threads about trouble people are haning with there transmissions. The question I have is I've got a 1995 f250 with 124,000mi on a e4od trans. I've heard that if you don't change trans fluid every 50,000mi to just leave it,but I also read that you probebly could change with no ill effects. What is the best answer to this?? Thank you to all that chimes in
Old Nov 22, 2012 | 09:51 PM
IowanStraight6's Avatar
IowanStraight6
What's it physicaly look like and smell like? Id change it myself and probably either do a flush or torque converter change cause by just droping the pan will only yeild 5--6 quarts
Old Nov 22, 2012 | 11:35 PM
khadma's Avatar
khadma
Carpenter Local 745
Don't forget a new filter.
Transmissions are the most overlooked service item, people wonder
Why a trans repair bill is so high.
Try a 250.00 service once in a while.
Old Nov 23, 2012 | 08:54 AM
Intimnasc's Avatar
Intimnasc
When he says a Torque Converter change he is referring to the drain plug physically in the converter. Put a breakover bar and socket on the Harmonic balancer bolt and turn the motor until you see the drain plug in the converter. I can't remember if it is a 6 point or square drain plug so look the job over before starting as you may need and 8 point socket.
Old Nov 23, 2012 | 01:36 PM
jaagen's Avatar
jaagen
I was reading an artical and it said the guy has taken a trans filter with 300,000mi and there wasn't any debris inside so he suggest just to flush the trans via the cooler line on the rear of the transmission. The artical is on this site by Mark Kovalsky in the drivetrain/transmission,axle section.
bchitwood73
1997 - 2003 F150
Aug 15, 2012 08:41 PM
mikerans
15
Aug 24, 2011 09:18 PM
lincolnboy73
Mar 21, 2011 08:40 AM
Steve95
1978 - 1996 Big Bronco
Mar 14, 2006 07:57 PM
hotrodford_88
Mar 30, 2001 07:19 AM
