Getting mixed reviews from some other sources, so I figured I'd ask over here as well...
The truck has 128k miles on it, and I want to change the trans fluid before our upcoming towing extravaganza. Should I fork over the $$ to take it to a trans shop for a flush, or just do the usual drain/filter/gasket? I've only had the truck a few months, and the current fluid appears OK but I want to know it's good before we head out. Any tips for a DIY job on this particular trans?
The general consensus is that the drain and filter change is a better bet because the flush can dislodge gunk build up in the valve bodies and other transmission components. On older transmission this gunk settles into places where it doesn't cause any apparent problems, but can start causing problems when you flush it out and into parts of the transmission. I have seen several people on this forum testify that their tranny's were running great, they got a flush, and had to rebuild 5k miles later. I think a drain is you're safer bet. Just my personal opinion.
The dirty fluid is in the bottom of pan behind the filter.The converter spins so fast the fluid is well mixed and sent to the pan and filter. I never drain a converter unless Im pulling the tranny .And yes its a good idea to drain the converter but as long as you drop the pan and change the filter it will be fine . All the fluid in the converter is well filtered unless the converter is trashed.I recomend a drain plug to be installed in the pan at this time and drain and fill the pan twice a year . Change the filter every 3 and it will last nearly forever. Pat
ps. don,t flush unless you have enough money saved for a new tranny.
From 40 years personal transmission service experience . If it smells burnt it means the bands are going or gone.A filter change helps return the pressures back to normal increasing life . Fluid gets dark because its doing its job holding contaminates , it don't all have to be drained at once . Use my method like I stated and it always will be super clean . But If you want to do the converter to thats fine . I never do . your choice. Pat
ps. I always use lucas additive in high milers that are very worn .
I like the idea of changing the fluid in the converter as well, but some converters don't have drain plugs.
I've been flushing the the trans cooler by running a whole can of brake cleaner through the cooler after disconnecting both cooler lines then blowing it dry from both directions with an air nozzle.
