drop down battery box in very back
Old Aug 14, 2022 | 01:37 PM
rusty48's Avatar
rusty48
I figured asking for pros an cons BEFORE I actually do this. its a 50 f-1, gas tank has been relocated in rear. Im thinking of mounting on the brace channel behind the tank. Pretty good access, yes along way and if I get rear ended bye bye battery. Have not run exhuast. and running a flathead with an AOD.
Old Aug 14, 2022 | 01:54 PM
1949f1's Avatar
1949f1
on my 49 the drop down box is on the frame on the right side just behind the cab. I added battery jumper studs under the right running board for charging
Old Aug 14, 2022 | 02:45 PM
49willard's Avatar
49willard
I used the same location as Tracy but put the "jump posts" in the engine bay.
Old Aug 14, 2022 | 03:50 PM
Gwilkrrs's Avatar
Gwilkrrs
that’s how I plan to do mine also
Old Aug 14, 2022 | 04:51 PM
rusty48's Avatar
rusty48
Didnt think about that, the x pipe in the exhaust looks to leave quite a bit room, Did you weld a box/backing plate to mount the battery box to?
Old Aug 14, 2022 | 08:23 PM
49willard's Avatar
49willard
Kevin,
I did weld in a plate to support the drop down battery box. Don't be confused where the box is located relative to the original stock crossmember. The original stock crossmember has been moved back more than a foot but retained to retain rigidity in the frame but allow the room for the 700R4 AOD.
Old Aug 15, 2022 | 11:28 AM
rusty48's Avatar
rusty48
Thanks Bill, I would have used that for reference. I have the cab in prep for paint and was not planning on pulling it off for paint as its in good + shape. Decisions...............
Old Aug 15, 2022 | 11:37 AM
jniolon's Avatar
jniolon
old and in the way
There is also plenty of room outside the frame rail under the cab... with a trans cooler inside the frame
but I've found out that it's not a convenient place if you need to remove battery from a low truck... here's mine
https://jniolon.classicpickup.com/batterybox/batterybox.htm
https://www.fordtruckzone.com/thread...-f-100.664344/
john
gary's1950F1
Aug 22, 2018 09:17 AM
crewchief99
13
Aug 2, 2014 09:39 PM
tomrflorida
May 8, 2014 07:56 PM
aldrowsboy
Dec 1, 2013 11:33 PM
Redgranite_Yooper
Aug 25, 2013 08:44 PM
