Identifying LS Diff/Possible issues
Old Aug 8, 2022 | 08:06 PM
slurpeemcflurpee's Avatar
slurpeemcflurpee
Excuse my very greeness. I was checking out a rear end today and wondered if this was usual. It's sitting on jacks with no tires or driveshaft. When I spin one axle shaft by hand the other side spins in the same direction but skips intermittently. If I hold the driveshaft yoke they spin at the same speed, no skipping.
Is that usual or a sign of something being wrong?
Old Aug 8, 2022 | 08:33 PM
440 sixpack's Avatar
440 sixpack
If the pinion turns rather than the wheel that doesn't mean much on an open rear. on a posi they should both turn the same direction smoothly.
When you hold the pinion do they turn the opposite direction ? if so you have an open diff. if they turn the same direction you have a problem.
Old Aug 8, 2022 | 08:55 PM
slurpeemcflurpee
When I hold the pinion they turn the same direction smoothly. When I let the pinion go the other side continues going the same direction but seems to be skipping.
Old Aug 8, 2022 | 09:07 PM
440 sixpack
On a posi rear if you hold the pinion you souldn't be able to turn the either wheel. if it's open they go opposite directions.
I'm guessing your gears or an axle are toast .. if it's a 60 pull the cover and look.
brettdacosta
Apr 12, 2021 03:42 PM
loquito
Aug 18, 2016 01:31 PM
Alex Bindas
Mar 16, 2014 04:23 PM
rowdy123
Jul 27, 2005 07:31 PM
SPRINT 12
May 9, 2003 01:40 PM
