Driveshaft installed wrong
Old Jul 27, 2005 | 11:31 AM
rowdy123's Avatar
rowdy123
I have a 79 F-150 4x4. When I first purchased this vehicle the driveshaft was installed wrong. It had the slip joint near the rear differential. I reversed it so that the slip joint is now near the tranfer case. Since then, I started to look at each 73 to 79 ford 4x4 (particularly the short beds) and noticed that about 75% of them had the driveshaft backwards!
When I asked my local Ford Dealership about this, the mechanic shook his head and said that about 50 to 60 percent of the Ford trucks he works on come in with the driveshaft mounted backwards. He usually leaves them as they are, but could not offer any "benefits" as to why this happens.
Any ideas?
Thanks
Old Jul 27, 2005 | 12:24 PM
ivanribic's Avatar
ivanribic
The only time I've seen them like this is when the driveshaft is a double cardan (CV) at one end. The CV end is alway mounted at the T-case and the slip yoke will be opposite end, as my front driveshaft is. I haven't seen any stock trucks with a rear CV driveshaft though.
Old Jul 27, 2005 | 04:29 PM
longview1's Avatar
longview1
Banned
I also see lots, one peice drive shafts with slip joint at the axle end.
Mine is/was also like that, but u-joints at diff and t-case are not the same size, so ya cant just turn 'er around.
And why is it backwards? It has the same effect either way doesnt it?
Old Jul 27, 2005 | 05:07 PM
fellro86's Avatar
fellro86
believe it or not, my old 75 had the cardan joint right off the case to the rear axle, as well the front driveshaft... it was stock setup as far as i know, it did not have any addtional lift...
Old Jul 27, 2005 | 05:32 PM
ivanribic's Avatar
ivanribic
I was wondering if they used these in the back of short box trucks. It would make sense but I don't see enough short boxes to check and the one I have has no driveshafts.
Old Jul 27, 2005 | 06:43 PM
fellro86's Avatar
fellro86
my 75 was a long box 250 4wd, one of the "highboys" Divorced case ... had a real short driveshaft, I think the front actually was longer than the rear.
Old Jul 27, 2005 | 07:07 PM
ivanribic's Avatar
ivanribic
Off topic a bit but I always thought (for a rig that took a lot of abuse) it would be cool to center a divorced case on a truck so both drivelines were the exact same length. Then you could carry 1 spare that could replace front or rear if something happened.
Old Jul 27, 2005 | 07:31 PM
MBBFord's Avatar
MBBFord
My Bronco has CV joints front and rear. I know what you mean Ivan, about the drive shaft being the same length. I've always wanted to get a truck with front and rear D60s, it'd be some much easyer to bring parts on a trail for only one type of axle, and drive shafts being the same length would be nice too.
