Driveshaft problems
Old Mar 13, 2014 | 06:31 PM
Alex Bindas's Avatar
Alex Bindas
Driveshaft problems
Okay so the U-joint on my driveshaft went out and it fell off on the freeway. I had a new driveshaft and slip yoke made for the truck and I installed it on my 88 f250. It is a one piece driveshaft. But I just drove it down the road and it is shaking like its unbalanced. Now the driveshaft was balanced though... Anyone have ideas as to what it could be?
Old Mar 13, 2014 | 07:19 PM
rla2005's Avatar
rla2005
If it did not vibrate before the u-joint issue then I would say someone did a poor job "balancing" the new driveshaft.
What year/model/engine/transmission truck do you have?
Old Mar 13, 2014 | 08:22 PM
300-six's Avatar
300-six
I would say u need to have all three pieces driveshaft slip yoke tranny side and diff yoke axle side all balanced at one. As far as I know this is how they do it at the factory and I have made the mistake of not marking my driveshaft when replacing u joints and reversed the alighnment of the yoke it vibrated like crazy. Went back to the garage and turned the yoke then she was smooth as butter. Check both of these things likely to be one or both causing ur problem
Old Mar 16, 2014 | 04:23 PM
Alex Bindas
Found problem
As an update the transfer case has a broken casting. I jacked it up and put it on stands and let the clutch out and could see it wobbling there. Haven't taken it off yet but i would guess that the output shaft from the tcase is bent or something...
1995Ford250
Mar 28, 2006 03:42 AM
51dueller
Oct 15, 2004 12:09 PM
harmdogg1978
Sep 27, 2004 10:25 AM
rmauch
1983 - 2012 Ranger & B-Series
Feb 17, 2004 10:21 PM
stangman67
Nov 11, 2003 05:35 PM
