Hood Heating up
I am leaving Friday for a 15-20 hour road trip and am worried something might be wrong. Maybe the coolant sensor or thermostat? Anyone who can guide or help me out would be very nice, I want to put all chances on my side for this trip as we are driving to catch a plane for a fishing trip... If we miss this plane, trip is cancelled
).Thanks alot in advance!
The hood can get too hot to touch from the sun beating down on it. I don’t recall the hood being too hot to touch even in cars with steam puffing from under the hood. Nor the metal frame above the radiator. The 460 is a monster of an engine and the hood is relatively small with not much contact with other body panels to channel heat so who knows.
I’d rent a tool to pressure test the cooling system and radiator pressure cap, replace the thermostat and gauge temp sender before the long trip. Collect and reuse the coolant if it’s a recent fill. Filter it through an old t-shirt if there’s already bits and stuff in the coolant.
It’s possible you have a head gasket or other breach allowing combustion pressure into cooling system. Maybe check the coolant for exhaust gasses. Parts stores should have a test kit for this. Start the cold engine and let it idle for 2-3 minutes. Shut it off and feel if the radiator hoses are already stiff. Slowly release the radiator can and listen for a rush of air. That would indicate excess pressure in the cooling system,
Sixto
07 E350 5.4 183K miles
Sixto
Thank you very much for taking the time to reply, it's really appreciated!
These temp gauges are junk. It can take a 20-30*F swing to move a pointer’s width. Coolant temp varies quite a bit with everyday driving but manufacturers think seeing all that movement would concern the average driver so the pointer stays at a fixed position within C and H so drivers don’t panic wut every little variance.
If the temp gauge isn’t rising as high as it used to, it could be the thermostat is stuck partway open. This makes the engine take longer to get to operating temperature, then unable to cool properly under load. It could be stuck from corrosion after sitting in tap(?) water for so long.
Sixto
If you're able to pressure test the cooling system I'd also check the radiator cap---they can weaken over time and use.
Good luck with this!
