11' Hood Insulation missing Underside?
Old Dec 8, 2011 | 04:51 PM
diesel smoke's Avatar
diesel smoke
Plowed all night and day and a couple times I noticed water sizziling on the topside of hood of this 11' 6.7 PSD. Called Ford today they say a hood insul. panel not listed in parts breakdown for this truck. Anybody else notice this issue any paint probs out there????
Old Dec 8, 2011 | 05:24 PM
Andrew010's Avatar
Andrew010
Water actually sizzling or just melting on the hood? I wouldn't imagine the hood should be hot enough to almost boil water. The snow should melt on the hood but still be cold water, not hot enough to sizzle off the hood.
Old Dec 8, 2011 | 05:37 PM
ruschejj's Avatar
ruschejj
The only part of the truck that gets hot enough to boil water is the exhaust header and tailpipe. Hood insulation or not, nothing on top of the motor even gets close to being that hot. Water and oil temps barely reach 210 F unless it's a really long grade with a heavy trailer.
And, I don't think any of us have a liner on the underside of the hood.
Old Dec 8, 2011 | 06:12 PM
TRENT310's Avatar
TRENT310
Although when outside temperatures are cold, even lukewarm water will look like it's steaming.
Old Dec 8, 2011 | 07:30 PM
lexustbs's Avatar
lexustbs
the gas versions have insulation under the hood. You can order the part and install it yourself. Ive heard it cuts down on noise alot.
Old Dec 8, 2011 | 07:58 PM
diesel smoke
Talking about water audibly melting off the hood. What are the SS flex pipes right under the hood part of the EGR system? While inspecting today I found the adhesive between frame work and hood panel is dried, cracked and hard, near the outside this stuff still has elasticity.
Old Dec 23, 2011 | 08:56 PM
Delawhere?'s Avatar
Delawhere?
Does anyone know what part no. for the gas versions?
Old Dec 23, 2011 | 11:23 PM
powerstroke72's Avatar
powerstroke72
Try this:
2011 Ford F-350 Parts - www.partsguyed.com
It's part #2. Of course, you'll also need the corresponding clips/retainers, etc.
Old Dec 24, 2011 | 12:08 AM
Strokin'Hokie's Avatar
Strokin'Hokie
I'd imagine it's not there for a reason... Might rest against something hot and burn or cause issues if it's not meant to be there. Haven't any issues with mine, but I guess it isn't on any of the diesel models...
410 Highboy
Apr 4, 2009 01:16 PM
Gun-Driver
Feb 4, 2008 10:15 PM
jomes
29
Mar 28, 2006 07:55 PM
landjr
Jul 8, 2005 11:12 AM
Thomsen
Offroad & 4x4
Apr 13, 2004 02:00 PM
