7.3 Diagnostics tool options
Old Jul 27, 2022 | 02:16 PM
352Ford's Avatar
352Ford
Looking for a service tool to troubleshoot some suspected fuel system issues in my E99 7.3 powerstroke.
AE is out of stock due to micro chip shortages and has no idea when they will come in.
What other tools out there can do some basic data logging of engine sensors and actuators (including ICP, IPR, etc.) on the 7.3?
HP tuners?
Others?
Old Jul 27, 2022 | 02:26 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Your best option for troubleshooting and price right now is FORScan via a mobile device for $5 or Windows laptop for free.
The links provided below are in the 7.3L PSD Tech Folder, as well as a LOT of others that may be useful to you.
Start with the last link, which is the Q&A.
FORScanIf you are looking into fuel system issues like fuel pressure, be aware that this data is not accessible via FORScan or any other OBDII scan tool.
Check out the following link for identifying fuel pressure.
Link: Fuel Pressure The Easy Method
Old Jul 27, 2022 | 02:44 PM
352Ford's Avatar
352Ford
Thank you, the lack of fuel injection parameters and general oddness of a non OBDII truck with a OBDII connector is why I decided to post this question.
I was hoping to be able to record IPR duty cycle measurements and such, not just mechanical fuel pressure to help pinpoint my issue.
If AE was in stock I would totally buy it, but really hoping there is another option that's reliable.
Old Jul 27, 2022 | 02:57 PM
udsuth78's Avatar
udsuth78
Sous has it right. Forscan is THE best there is for streaming and recording live engine PID's. If the PCM can see it Forscan will show it to you. Also preforms all available self test and will even bleed the ABS system. I've got AE and Forscan both and hands down prefer the Forscan. The user controls learning curve is considerably better, probably because is intended for the general public not dedicated mechanic shops. Plus it is specifically designed for Ford and affiliate engine management systems.
Edit: IPR DC% as well as ICP, EBP, EOT, TFT, MAP, MAT, IAT, Injector Pulse Width, Mass Fuel Desired and many many more are all viewable w/ the Forscan software and a compatible OBD2 dongle.
Old Jul 27, 2022 | 03:21 PM
352Ford's Avatar
352Ford
Perfect, that is what I needed, thank you. I will download Forscan.
Old Jul 27, 2022 | 04:31 PM
Sous's Avatar
Sous
FTE Emeritus
As udsuth78 said, all of that and more is well within the wheelhouse of FORScan or FORScan lite.
Below are a few examples of what you can do with FORScan or FORScan Lite.
Use the PID Charting Tool in the link below to make the wall of text that a data log is look like the graph below with easily identified PID's and values.
Link: PID Charting Tool ***Improved Version***
Visual aid:
You can take screen shots or keep a data log as a "good running condition" for future reference if you need to compare apples to apples during an issue.
Visual aid:
If your feeling froggy and want to see the graph lines and screenshots come alive, you can make that happen too.
Link: Virtual gauges, data logs and making it all make sense...
Visual aid:
Get your software and hardware sorted out and keep us updated!
Untamed_diesel7.3
Jul 24, 2021 01:16 AM
Model a ford
Oct 4, 2020 01:44 PM
ReedRepower
Virginia Chapter
Aug 18, 2011 09:45 AM
spudgunman
Washington Chapter
Feb 10, 2010 11:49 AM
robjs111
Apr 9, 2007 02:49 PM
