Two minor issues - any ideas?
Old Jul 21, 2022 | 09:59 AM
eagle243's Avatar
eagle243
Hi, all.
First, recently my 2013 4x4 has started engaging the rear diff lock even when I don't request it. The solution so far has been to tap on the switch or to engage the lock and disengage it (pull & push switch). I'm assuming that these are super easy to change (a few clips, or maybe more than a few clips to get the trim out, and maybe I need the center stack out first, but then it should be unscrewing and unclipping the switch, and then reversing that process). Is this a common failure?
Second, a while ago on these boards I reported that my 2013's steering wheel audio controls quit working correctly (pressing forward ends up going back to the start of the song; forward increases volume; whatever; weird things like that). The solution, I was told, was to replace the switch grouping. I did that, and it worked for a month or so but now the problem is back. I bought a set on eBay; did I just get a second bad set? Do I need to buy a new one from my local dealership? It was super nice to have working steering wheel audio controls, and I'd like to have that again. I'm not insane, though, so I don't want to repeat this process with the same result. Any way to have a better result?
Thanks, all.
Old Jul 24, 2022 | 11:20 AM
Siberexpress's Avatar
Siberexpress
If it is not the switch, it could need the clock spring replaced.
Was the switch you replace the original one with a Ford part or aftermarket, Fords have a notorious problem with aftermarket electric parts.
Old Jul 24, 2022 | 01:14 PM
eagle243's Avatar
eagle243
Thanks, I'll get a genuine switch and then replace that. I'm sure that will fix it.
Old Jul 25, 2022 | 09:08 AM
explorerdriver's Avatar
explorerdriver
Switches are just resistors. They pass thru the clock spring and end up somewhere under the steering wheel. They go into a box that converts the resistance to CAN network requests.
If you have a wiring diagram, you could certainly test the switches (there is a resistance value for each).
flumpydog
Mar 20, 2021 10:41 PM
foxman350
Mar 19, 2010 08:28 PM
brian.taylor
Jul 2, 2009 06:20 AM
n5926g
1997 - 2003 F150
Feb 7, 2009 03:43 PM
bigtorque
Oct 19, 2006 10:15 PM
