T/c Lock Up
Old Oct 18, 2006 | 10:50 PM
bigtorque's Avatar
bigtorque
T/c Lock Up
can any one shed some light on this product, its a lock up switch, but im wondering if any one has used it, and or could you potentily hurt your T/C.
also, what do they mean by momentary switch?
http://www.puredieselpower.com/catal...-kit-p-85.html
Old Oct 19, 2006 | 08:55 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's essentially a prepackaged version of the TC mod done by folks on this site. Should work fine, but I have no experience with it.
A momentary switch is usually a pushbutton or a wide open throttle switch...Things of that nature. Power is only applied when you are holding the switch closed.
Old Oct 19, 2006 | 09:05 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
on the TC switch, the normal lock position is when you push down on the switch, it stays in that position and keeps the TC locked, no matter what. the momentary position is the upward direction. if you push up on this, it will lock the TC "momentarily" and then return back to center position. i have not seen a use for the the momentary part of the switch in almost 8 months.
Old Oct 19, 2006 | 10:15 PM
bigtorque's Avatar
bigtorque
appreciate the info.
it doesnt sound like something i would want though.
Samorkand
Modular V10 (6.8l)
Jun 16, 2012 04:58 AM
camodown
Feb 8, 2009 07:26 AM
matt f350
Nov 10, 2008 05:35 PM
audimaster
Oct 21, 2008 11:23 PM
conman3300
Aug 19, 2008 03:10 PM
