intermittant ignition switch problem
Old Jul 2, 2009 | 05:56 AM
brian.taylor's Avatar
brian.taylor
I had the dreaded no-start from my ignition switch. first, I dropped the steering wheel and adjusted the switch forward. That worked for a few cranks, then quit again.
The lock cylinder and rod seem to rotate ok, but it just wouldn't crank.
I went a couple of days using the the screwdriver method.
Yesterday, I replaced the switch with a BWD branded replacement from oreilly's.
Its doing the same thing that it was before! I'll drop the steering wheel, make sure everything is where it should be, test crank it, everything will work fine, I'll put it back together, then when I go to start it later in the day - NO START.
Drop the steering wheel - check everything - cranks fine - 30 min later, no crank. I'm stumped.
Ideas?
1989 F-150 Supercab 5.0
Old Jul 2, 2009 | 06:20 AM
60F100's Avatar
60F100
It could be in the park/neutral safety switch. When it won't crank try wiggling the shift lever, if that works then the safety switch is either bad or out of adjustment
1975FordF250
Aug 12, 2015 12:12 PM
BillC1009
Aug 12, 2012 07:53 PM
bozzchem22
18
Nov 18, 2009 09:41 PM
Torsen Rick
Aerostar
13
Oct 16, 2009 06:47 PM
starmilt
Nov 18, 2008 05:39 PM
