VanTurbo Downpipe
Old Jul 22, 2022 | 07:00 AM
SkySkiJason's Avatar
SkySkiJason
You can make a stock SD downpipe fit with some clearancing on the firewall and downpipe. It will need shortened up so it fits tight under the cab IIRC - it’s been awhile since I did this......
At a minimum, you’ll want fresh cab mounts - but a little body lift definitely helps make room for dp on the OBS.
The van turbo has a smaller outlet for dp than SuperDuty turbo. It’s also a 1.15AR exhaust housing - generally not considered an advantage for stockish power 7.3.
Old Jul 22, 2022 | 03:18 PM
SVandal's Avatar
SVandal
I think I can make the OBS diamond eye fit with an extension. I cut the down pipe last night and cut the welds off of the turbo adapter. It may be a little tight. I picked the van turbo because it should give better flow than the OBS turbo, it fits the larger plenums and a larger spyder and the outlet fits the OBS downpipe. If I were going for big power then I would have gone with something else.
SVandal
Aug 29, 2021 05:41 PM
7.3 Rocket
25
Nov 4, 2010 11:13 AM
eiznekcm
Jan 31, 2006 10:08 PM
10MPG
May 27, 2005 04:48 PM
