1963 speedometer bezel seal help
Old Jul 18, 2022 | 05:29 AM
mote's Avatar
mote
Howdy All,
Starting to put the interior back in the truck. The previous owner broke the speedometer glass bezel when they removed it. I was able to buy a new one from LMC however they were out of the seal that goes between the glass and the panel (item 5 below). I can't seem to find it anywhere. Is it anything special or can I just use black rtv ?
Old Jul 18, 2022 | 07:06 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Is there an estimated “back in stock” date? I’d be inclined to be patient and wait on the right material. If someone chimes in with a part number, you can search on RearCounter or PartsVoice.
But read this for alternatives:
https://www.ford-trucks.com/forums/4...und-glass.html
Old Jul 18, 2022 | 07:54 AM
mote's Avatar
mote
I just checked the LMC site again.
For the seal it says "temporarily out of stock, no backorders"
Old Jul 18, 2022 | 05:18 PM
fivestarmmd's Avatar
fivestarmmd
I had local glass shop cut me couple while back, little over 3 dollars each. Just used black silicone to retain.
Old Jul 21, 2022 | 12:14 PM
mote's Avatar
mote
Thanks for the responses.
LMC doesn't have a date for when it will be back in stock so I may just go the RTV route. I'm fixing this truck to be a driver and not a show truck so I don't mind to go the rtv route.
Old Jul 21, 2022 | 05:20 PM
stonewalljac's Avatar
stonewalljac
Looks like everyplace is out of them
Old Jul 25, 2022 | 02:08 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I used some stuff they call "Dum-Dum" at the body shop. Looks like strips of black licorice. Sticky, stretchy. Seems like a better alternative than trying to remove rtv at a later date.
Old Jul 25, 2022 | 03:15 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I think Dum-Dum is the same as butyl rubber. That stuff comes in caulking tubes, strips, tape, rolls, sheets, etc. They make gloves out of it. Probably many more things that I'd ever realize. Black and sticky/stretchy in some forms. Grab a golf ball sized blob of it and on a piece of parchment paper you can roll it under your hand to make a custom sized piece of licorice to use around the edge of the glass. I say on parchment paper just so you have a nice non-stick surface. That stuff will pick up any debris so doing it on a dirty workbench probably not the best.
Amazon.com: TP Tools Black Automotive Strip Caulk TP-1070, 2 Lb Box : Automotive Amazon.com: TP Tools Black Automotive Strip Caulk TP-1070, 2 Lb Box : Automotive
Old Jul 26, 2022 | 11:32 AM
Thunderkiss1965
TA455HO, That's the stuff! The 2# box is well worth it, one can find lot's of uses for it on these old trucks.
Dan TK65
Old Jul 26, 2022 | 02:06 PM
daveengelson's Avatar
daveengelson
I used the instrument panel seal cut to fit in place of the speedo seal?
Old Jul 26, 2022 | 02:14 PM
TA455HO's Avatar
TA455HO
Lead Gopher
A question mark on the end of that. Did you, or didn't you? Or you don't quite remember? If that question is for us, I sure don't know...hahahaha
Old Jul 26, 2022 | 05:56 PM
daveengelson
Although there are a number of options in securing the round speedo to the panel, sorry , though I made the thread fairly clear, I did use the instrument panel sear and then cut to the desired length.
Old Jul 26, 2022 | 08:46 PM
BobbyFord's Avatar
BobbyFord
Thick cork gasket material, cut to circumference works too. Been in my truck for 30 years.
Old Jul 29, 2022 | 04:20 AM
mote's Avatar
mote
Thanks for all of the ideas.
I was talking with the guy I bought the truck from and he has a roll of the butyl rubber tape that he's been using to restore his '66 step-side.
He's going to bring some over so I can fix my speedometer.
Next is the gas tank. It needs a lot of cleaning as they inside is full of rust flakes.
motogotor
Aug 17, 2022 01:18 PM
daveengelson
Oct 14, 2015 09:50 AM
rwkinch
Nov 28, 2012 06:59 PM
mtpcage
Mar 22, 2006 11:50 AM
Stingray42
Sep 22, 2003 08:11 PM
