Rear Window seal
Old Aug 24, 2003 | 04:39 PM
Stingray42's Avatar
Stingray42
Rear Window seal
I am replacing the rear window in my 84 Ford F150. It is a slider, but broken and I am replacing with a solid glass, which I already have. The seal is still there. If I remove the seal, will I be able to get a new one? I am getting a glass company to install it, they should install a new seal, right?
Thanks!
Old Aug 24, 2003 | 07:11 PM
steve83's Avatar
steve83
Rear Window seal
No, they won't put on a new seal unless you buy it. You should have gotten the seal when you got the glass. Most junkyards cut the seal to remove the glass, but it's easy to get them out together.
Old Aug 25, 2003 | 01:11 AM
Ford_Six's Avatar
Ford_Six
Rear Window seal
The seal should be the same for slider or solid glass, just tell the glass co to re-use it.
Old Sep 22, 2003 | 08:11 PM
Gobstopper909's Avatar
Gobstopper909
Rear Window seal
Careful. givin the year and being weathered, the factory seal is prabably no good. mine went right after i put a slider in so i yanked it out and its now good as new. it started leaking in the both bottom corners. I hope this helps good luck
Becky_is_a_66
Oct 4, 2025 11:16 AM
earth2lunarbase
16
Nov 11, 2020 04:22 PM
Doc
Aug 17, 2014 10:13 AM
Luch
Oct 17, 2013 03:43 PM
76 F150 Ranger XLT
May 13, 2006 04:35 PM
