starter solenoid issue
Old Jul 16, 2022 | 08:22 PM
i-w's Avatar
i-w
Question starter solenoid issue
Put in some new battery cables
Negative batt to engine ground.
New positive to starter solenoid.
All 2 AWG wire
Cleaned all contacts. Used die electric grease.
For some reason the battery drained
Nothing at all 3 volts at battery
Could I have hurt the starter solenoid when torquing down the new battery cable?
Before I could let the truck sit for weeks and it has always started right up.
Thanks for the help.
Old Jul 17, 2022 | 09:34 AM
mark a.'s Avatar
mark a.
What led up to replacing the cables ?
Old Jul 17, 2022 | 11:08 AM
5851a's Avatar
5851a
You need a super thin backup wrench torquing solenoid bolt, but if you damaged it, you would have known it. It sounds as though you have a steady draw on battery. Any chance you have glove compartment lamp on or aftermarket radio? Brake lamps stuck on? Dome lamp? Old style mechanical voltage regulator with stuck points? Just a process of elimination.
Old Jul 17, 2022 | 11:25 AM
i-w's Avatar
i-w
Thanks,
The cables were corroded very hard and the covering was cracking.
As far as a draw, I believe it has been there to some extent.
I think I over torques the starter solenoid bolt and it twisted inside.
I did recall seeing a turn signal dimly lit when driving at night and lights on.
Nothing else seems is on as you mentioned.
JRT812
Mar 30, 2020 10:12 PM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
torquemeister
Dec 5, 2007 12:57 PM
itcosthowmuch!!??
1978 - 1996 Big Bronco
Jul 15, 2006 06:50 PM
Chris60F100
Dec 9, 2004 06:32 PM
