Sponsored by: Auxito
new remote entry fobs
Old Jul 16, 2022 | 09:54 AM
Mick88's Avatar
Mick88
3rd Gear
I bought some remote entry fobs after replacing the power door lock actuators. The instructions to program the fobs :
After performing step 1, the locks never cycle. Are these the correct instructions to enter programming mode for 2000 F150 XLT Triton?
I don't think the new remotes are at fault.
Any ideas ?
Old Jul 16, 2022 | 10:24 PM
Airborne 82nd's Avatar
Airborne 82nd
Automatic? Try it in neut. instead of park.
Old Jul 23, 2022 | 01:30 PM
Mick88's Avatar
Mick88
3rd Gear
Success ! Except it took 12 on-off cycles before I heard the locks cycle and I immediately touched the keys on the remotes now they both work.
I got some good support and advice from the Remote vendor: support@remotesremotes.com
"There are only a few reasons as to why the vehicle will not initiate programming mode.
1) If there is no keyless entry system on the vehicle. If you have never had a remote for the vehicle before, then you may want to call a dealership with the VIN to verify if it has a keyless entry system in it. If it does not then obviously you will need to return the remote but if it does, then the next reason would be the programming procedure.
2) If you are not performing the procedure correctly and/or fast enough, the programming mode will not initiate. Timing and accuracy are very important in getting your vehicle to programming mode.
3) Either the vehicles keyless entry system is damaged which is preventing the on-board programming procedure from activating OR there is an aftermarket system installed."
My vehicle is a 2000 F150 XL Triton I just bought last year. It has a lot of minor bugs that I am conquering little by little.
rc.chris
Jul 31, 2012 03:36 PM
valo
1983 - 2012 Ranger & B-Series
13
Jun 20, 2009 11:07 PM
Aussie Jones
Nov 6, 2008 12:02 AM
99 BAT
Nov 19, 2004 09:15 AM
frog1
1997 - 2003 F150
May 12, 2004 11:53 AM
