Engine Pull - recommendations to replace?
Old Jul 16, 2022 | 08:09 AM
BreezySkink's Avatar
BreezySkink
Trailering
Hello I'm going to pull the 4.9L engine from my '84 2wd f150 to replace the oil pan gasket. 4 speed manual
It has a relatively unknown history, what else do you guys recommend I replace with the engine out?
Thanks
Old Jul 16, 2022 | 08:23 AM
Franklin2's Avatar
Franklin2
I would replace all the external gaskets as well as the rear main seal. It may be cheaper for you to get a full gasket kit. You won't need the head gasket, but you will need everything else. All the rubber and gasket material gets old and hard with age.
While you have the timing cover off, take a look at the timing gear on the camshaft. They are made of a fiber material and though it's rare, they have been known to strip some teeth.
Old Jul 16, 2022 | 01:25 PM
32V GT's Avatar
32V GT
I would replace the motor mounts and transmission mounts. Most likely the rubber has dryed out and fallen apart.
Old Jul 16, 2022 | 04:07 PM
FuzzFace2's Avatar
FuzzFace2
Clutch, pressure plate, throw out bearing and pilot bushing.
Dave ----
Vibguy11
Jul 1, 2022 12:13 PM
waylen89
Feb 23, 2016 06:34 PM
1918ALF
Feb 25, 2013 07:08 PM
Nightrain
Feb 6, 2007 07:10 AM
waldreps
Apr 4, 2005 10:39 AM
