power steering pump
Old Aug 11, 2025 | 12:43 PM
  #31
1Butcher's Avatar
1Butcher
Originally Posted by Scndsin
Because you're part of the 33.3% of the people who got lucky with a C-2
That could be for certain but I usually am not the lucky one.
Old Aug 11, 2025 | 12:46 PM
  #32
My4Fordtrucks's Avatar
My4Fordtrucks
In this case you are.
Old Aug 11, 2025 | 02:03 PM
  #33
Soup bean's Avatar
Soup bean
I'll just add that my power steering pressure switch leaked when I first got my truck on the road. I topped off the fluid with cheap stuff until I replaced the switch.
Afterwards, I put Wolf's Head super universal full synthetic ATF in it, because I had it on hand, and it became shockingly quiet.
It currently has a very slow leak only in cold weather, which I need to troubleshoot this winter.
Old Aug 11, 2025 | 04:10 PM
  #34
My4Fordtrucks
I have always used Type F ATF. Some pumps are louder than others.
Old Aug 11, 2025 | 08:58 PM
  #35
Duke5A's Avatar
Duke5A
I've owned my '92 for 25 years and my grandfather owned it before that. The only drive accessory on the front of the motor to never have been replaced in 155k miles is the PS pump. Should I buy a lotto ticket? It will get a Saginaw at some point though.
Old Aug 12, 2025 | 07:32 AM
  #36
My4Fordtrucks
No one said the pump is failing. The problem with the CII pump is noise. Not that there aren’t Ford pumps that are quiet because I have owned vehicles with them. The Saginaw pump is always quiet and offers more power assist if you have bigger tires. My ‘87 Bronco has 35” and the Saginaw pump has no issue turning them when the truck is stationary.
Old Aug 15, 2025 | 01:07 AM
  #37
AuroraGirl's Avatar
AuroraGirl
The term 'There is no market' means you will not be able to make a profit if you sold them. I suspect there would be a minimum that you would have to buy for someone to design/manufacture a custom bracket. I can only guess, you would never even break even.......ever.
No matter how you look at it, the 4.9 was made for those that could not afford anything bigger or able to afford the gas to fill it up. Some people like the way a pickup is. There are those that need a pickup to do work. I cannot imagine anyone that wants a pickup to do work would prefer a 4.9. Yes, I am certain there is, but very very few. I don't know the ratio of the 4.9 vs the rest but I would believe they did not make many.
My daily driver is a 81 VW Pickup. It sucks as a pickup, is sucks as a daily driver, it sucks because it's too small for me. But I like it and I put around 20k miles a year on it. I would never disagree with anyone that would put down my truck. It is a POS. If I did not like it so much, I would agree with the facts. It's my truck and it works for me. I suspect that everyone that owns a 4.9 F150 feels just like me with my VW Pickup. It's ok to be weird, but the facts are, the 4.9 is not desirable for most people. If you walk out to your truck and it makes you smile, who cares what others think. If you think business' are going to make parts to keep that smile on your face, I think you are dreaming.
i am not really sure how to respond to most of that, but im not holding out hope for some benevolent person to reproduce a bracket for the saginaw. if i wanted to get the angle grinder and and drill out i can go make my bracket "work" for a saginaw, but im more content to sit and wait for a good local opportunity for bracketry or if the c2 whine machine dies , i have another used but presumably functional C2 in my posession
If THAT dies ,i may give the lee c2 pump a try because of novelty/see how serviceable/try it out, so i can report back to this community and then its rather plug and play, but theres a LOT Of thigns id rather spend 300 dollars on lol
Old Aug 15, 2025 | 01:13 AM
  #38
AuroraGirl's Avatar
AuroraGirl
type F isnt so bad but its pretty viscous
Id like to attempt a compatibility test with a seals from a obs ford gear box (if anyone wanted to send me one if they rebuilt or removed their old one, id love that) and try valvoline white bottle PS fluid, its thinner and it matches the spec that GM used when they stopped saying to use DEX III in the 90s and instead use PS fluid, for very good reasons.
TO my understanding, the only reason these trucks have type F is because its chemically benign and doesnt harm the gear box seals , the pump and hoses are of little worry ,and the teflon seal as well.
Type F doesnt behave as poorly as Dex 3 did in PS pumps (or Mercon V/Dex VI), but its thick and harder to get on shelves with time. I had asked for some at oreillies. ONE quart. in store. also highly recommend Seafoam trans tune to replace a portion of your ATF, it makes it thinner a bit and it helps remove varnish and debris and can quiet or make the pump a little lighter.
I must say my f150 steers quite fine, and periodically the thing will be buttery smooth and quiet , but i cant seem to nail down a pattern to why because it will just revert back at some point to whining loudly even idling
Old Aug 15, 2025 | 10:34 AM
  #39
My4Fordtrucks
I use Type F because that is what Ford put in there and what is recommended in the owner’s manual. Type F does not have the detergents that MERCON or other ATF fluids have in them. I put several hundred thousand miles on CII pumps in different vehicles. I converted two trucks to Saginaw pumps because they are better in every way. I looked it up once to see what fluid Ford used in the E- vans but I don’t remember if they used a GM spec fluid or Type F. How is that “white bottle” fluid different than regular p/s fluid?
Old Aug 15, 2025 | 10:46 AM
  #40
Scndsin's Avatar
Scndsin
I've used F, Mercon V & the Valvoline. (pump has been disconnected many times)
And the sag just doesn't seem to care.
I've settled on the Val for constant availability, it's clear, plus doesn't seem to have the ATF stink
Old Aug 15, 2025 | 10:48 AM
  #41
oval bowtie's Avatar
oval bowtie
Lee Steering has been around a very long time. The owner, Tom Lee, was very knowledgeable and willing to talk with anyone about their pumps and gear boxes. He even did some of the hydraulic work on the animatronics at Disneyland. Like I said, very knowledgeable in his field and not pushy to sell. I did a hydroboost on a G body El Camino and Tom blueprinted the steering box and pump. Fair price and quick turn around. I also had them do a steering rack and pump for a GM J-body. Extremely pleased with their work. Lee Steering even has their own power steering fluid and it worked well for me when doing a few projects. I still run it today when doing a system. Tom, I believe has retired and sold the business, but the quality should be the same. I too was also looking to do this pump for a few reasons : inline 6, improved pump, still uses over the counter power steering hoses, looks stock, and I like the work Lee Steering has done for me in the past. It is a shame that a lot of the early hot rodding guys are disappearing, but that is life and time goes on.
Old Aug 15, 2025 | 01:45 PM
  #42
sswari's Avatar
sswari
Interesting about the random changes. Mine is pretty much always audible at idle, but while moving, not so much.
Old Aug 15, 2025 | 03:29 PM
  #43
AuroraGirl's Avatar
AuroraGirl
it also runs cooler, if you were to compare synthetic ATF and the valvoline youd probably bbe amazed with the temp difference.
Problem of ATF esp synthetic is related to what happens to air in the system, and how it resists entraining air
Which all leads to heat too
Old Aug 15, 2025 | 03:30 PM
  #44
AuroraGirl's Avatar
AuroraGirl
If you do go and buy that, do show us what its like and perhaps pull the reservoir and valve to see what its all about lol
I have emailed them before and got very good answers, albeit not ones i wanted lol
Old Aug 15, 2025 | 03:49 PM
  #45
AuroraGirl's Avatar
AuroraGirl
The white bottle valvoline isnt pricy like their own synthetic formula is, doesnt contain stop leak (a lot of local ones are full of that junk), and its bottle certifies that its meets the standards of the AC Delco Power Steering Fluid ($$$$$$$$$$$$$$$$$$$$$$$$) , but different oz slightly. The colors are the same and the smells are the same, because that AC delco fluid is high end conventional steering fluid and gm has called for it 1970s-end of steering setups , only with cold climate( a synthetic thats thinner as well) and Pentosin CHF 11S for very niche high performance/needs/cold areas
So I think its the same fluid, but even if it isnt , the viscosity is different than a lot of those "PS fluids" Ive gotten, and not being red is nice for flushing/keeping clean/and not mixing up with ATF
Dex 3 suffered compatibility issues with seals for GM, mostly but was a little viscous and made heat, didnt bleed air well
Dex VI is an absolute no no in steering, and it does not bleed, and its wildly incompatible with seals,because of the bleeding, it cooks the steering too , but catastrophic damage is more likely with this
WalterRoad
Nov 19, 2018 10:49 PM
coreyallan01
Jun 24, 2014 01:18 PM
DILLIGAF13
Offroad & 4x4
55
Feb 26, 2011 09:15 PM
Mormakil
Aerostar
Jan 22, 2010 12:23 PM
Jeff-150
18
Feb 4, 2008 07:52 PM
