High Idle
Old Jul 15, 2022 | 09:10 AM
Glocklover72's Avatar
Glocklover72
High Idle
I know these truck aren’t supplied with a high idle switch, I installed one because I know or have heard that regular idling not good for the 6.7. So I did install one for long periods of idling if needed, mine boost rpm to 1200 and she purr's like a kitten. I do know that these trucks will go into a high idle mode in cold cold weather, at least mine has, but I noticed yesterday when I cranked it up in 99 degree weather it went into high idle which is around 1000 rpm, truck had been sitting for 10 hours. Has anybody else noticed this in 100 degree temps?
Old Jul 15, 2022 | 09:17 AM
redford's Avatar
redford
FTE Leadership Emeritus
100 degrees might feel hot to you, but it is still cold to your engine.
Also, was your A/C on? That can also raise the idle speed.
Old Jul 15, 2022 | 10:57 AM
4wd6.7L's Avatar
4wd6.7L
I have never experienced an elevated idle of 1000 rpm or more, in temps ranging from 14f, to 100f+. But, I have read plenty of posts from those who have. Towards the end of this thread you will find others who may be experiencing the same as you, with hot weather being the suspected reason.
https://www.ford-trucks.com/forums/1...requested.html
Liquid10Rider
6.7L Power Stroke Diesel
Jan 21, 2019 11:07 PM
2000F250guy
Dec 14, 2011 07:45 AM
akorcovelos
Nov 3, 2010 10:30 AM
Golflug
25
Feb 11, 2008 09:38 PM
Mike F250
Mar 17, 2007 09:22 AM
