Thumping sound
Old Jul 14, 2022 | 09:38 AM
bvieages's Avatar
bvieages
Thumping sound
I have a 07 250 6.0 with 146K miles. Recently it developed a thumping sound that sounds like it's coming from right behind the driver seat. I have put additional supports under the jump seats, removed everything that isn't nailed down, been underneath checking and pulling on everything. Took the rear shocks loose to see if they had gone bad. Has anyone else run into this problem. It gets very irritating after a while. Thanks.
Old Jul 14, 2022 | 10:40 AM
TooManyToys.'s Avatar
TooManyToys.
Usually cab mounts.
Old Jul 15, 2022 | 10:49 AM
Yahiko's Avatar
Yahiko
The other thing to look at would be the driveline center support bearing.
Look to see if the rubber has cracked around the bearing.
Old Jul 18, 2022 | 01:41 PM
HydroTek's Avatar
HydroTek
S&B silicone mounts -- take the truck thru a place that will twist the body some, like a driveway entrance or crossways (45 degrees) to a speed bump
if the mounts are bad the twisting of the body will make all sorts of interesting sounds
Old Jul 20, 2022 | 02:57 PM
Mich6.0's Avatar
Mich6.0
check your anti roll linkage, when they wear out, they clunk
Old Jul 20, 2022 | 03:38 PM
Yahiko's Avatar
Yahiko
I forgot about that. Mine was doing it until I got a new set of front bushings for the bar.
They are easy to put in being a split bushing that you just slip over the bar and two bolts for each
clamp that holds them in place.
I have not had to do a rear set yet. I think they are more or less the same thing.
Old Jul 27, 2022 | 08:49 AM
bvieages's Avatar
bvieages
Thanks for the info
I looked and the cab mount bushings look deteriorated. Is this a fix i can do myself ? If so, is there something in the Tech manual that has a "how-to"? Thanks again for the help.
Bryan
Old Jul 27, 2022 | 10:00 AM
chick's Avatar
chick
Lots of videos on You Tube. Check the video on S&B site, yes you can do it yourself with some effort. Note that S&B will not warranty if you do it yourself according to their site. I ordered a set and will have them installed as i have no flat driveway, and it will be over 100 degrees here for the foreseeable future. I will do a lot on my own but not willing to roast to do it.
Fordfvckinranger
1983 - 2012 Ranger & B-Series
Nov 16, 2021 12:55 PM
JoeAndre
Jan 22, 2008 06:25 PM
King of the Ranch
Nov 4, 2007 01:34 PM
