Deceleration Rattle
Old Jan 21, 2008 | 09:07 PM
JoeAndre's Avatar
JoeAndre
Thumbs down Deceleration Rattle
6.0 Turbo....when I take my foot off, I hear a sheetmetal rattling sound. Hit the peddle and it disappears....What is it????
Old Jan 21, 2008 | 09:27 PM
slowmans's Avatar
slowmans
its normal...........
Old Jan 21, 2008 | 09:41 PM
JoeAndre's Avatar
JoeAndre
But, it only started recently....?
Old Jan 22, 2008 | 05:54 AM
slowmans's Avatar
slowmans
unless something is loose? They do have a similar sound when decelerating...
Old Jan 22, 2008 | 09:37 AM
drakul20us's Avatar
drakul20us
info on the truck. have you done anything to it? my truck makes a rattling noise when I take my foot off the pedal while foing 40 - 70mph, at high speed, high rpms and high boost. I think that it's just the intake cutting out. I would check all the boots on your intake plumbing, from the turbo throught the intercooler to the intake elbow.
Old Jan 22, 2008 | 04:11 PM
UGA33's Avatar
UGA33
I had the same issue to around 35 mph rolling to a stop it would get a grinding/rattling noise. Next day, it was on take off too. Turned out to be my MBRP downpipe was sitting on a crossmember bolt which caused it all. If you have an aftermarket exhaust i would look to see where it is hitting.
Old Jan 22, 2008 | 05:04 PM
MPHorvat's Avatar
MPHorvat
Does the fuel shut off upon deceleration (w/ manual transmission)? If I'm at a cruise and lift the throttle slightly, the tone remains basically the same. OTOH, if I lift off the pedal completely, it sounds much different, making me wonder if the computer shuts off fuel altogether, perhaps to aid engine braking or something like that.
Thoughts?
Mark
Old Jan 22, 2008 | 06:04 PM
pk8950's Avatar
pk8950
I also had that same problem on both my trucks. It was the down pipe rattling against the rivit that holds the firewall insulation on. 4" magnaflow pipe.
Old Jan 22, 2008 | 06:25 PM
3000 FPS's Avatar
3000 FPS
If you have a after market down pipe I would start there or loose exhaust start from the turbo back and grab it and check it.
Richwon4
Aug 13, 2016 05:48 AM
darmento
Apr 20, 2016 07:03 PM
khelms_98
Mar 25, 2005 08:44 AM
feddoc
16
Feb 21, 2005 09:12 PM
travlnman
3.8 & 4.2L V6
24
Jan 25, 2004 07:44 PM
