Oil Temps.
Old Jul 14, 2022 | 02:00 AM
CGriff71's Avatar
CGriff71
4wd Low
Oil Temps.
I have a 04 F250 ccsb 4x4 6.0 with a 7.3 fan clutch. I am pretty sure I have a bad one since I don't ever hear it come on. Is there a way I can manually hook up a switch with the 7.3 fan clutch?
Old Jul 14, 2022 | 05:04 AM
bismic's Avatar
bismic
What is your concern with regard to oil temps? I assume you have modified your truck to run a BulletProofDiesel (or equivalent) air cooled oil cooler?
Old Jul 14, 2022 | 08:32 AM
TooManyToys.'s Avatar
TooManyToys.
A 7.3L fan clutch is not electrically controlled. It does what it does.
Old Jul 14, 2022 | 06:10 PM
CGriff71's Avatar
CGriff71
4wd Low
I still have factory oil cooler. I changed the oil cooler bypass valve and the oil Temps went down about 10°. Usually the ECT runs about 188-192°. The EOT will run any where from 219°- 230°, depending on style of driving. But when I take it easy or stop at a light, EOT will start going down after a couple minutes.
Old Jul 14, 2022 | 06:13 PM
CGriff71's Avatar
CGriff71
4wd Low
And I know the 7.3 fan clutch isn't electrically controlled. I don't think mine works. I haven't ever heard the fan noise. I was just wondering if there was a way to wire in a switch until I had a chance to go in and change it.
Old Jul 14, 2022 | 06:27 PM
bismic's Avatar
bismic
If ECT runs 188-192, then I don't think high oil temperatures are related to the fan (seeings how you have the OEM oil cooler).
Old Jul 15, 2022 | 08:47 AM
Byrd.Dog's Avatar
Byrd.Dog
7.3 clutch is viscous - engages more & more as airflow through the stack gets hotter. So if your ECT is running 188-192, fan is probably not fully engaging. Your oil temp issue isn't related to the fan. Might try backflushing the oil cooler?
Old Jul 15, 2022 | 09:24 AM
Antonm's Avatar
Antonm
if you know the 7.3 fan clutch isn’t electrically controlled, then how on earth do you expect to put a switch in it??
Old Jul 15, 2022 | 05:52 PM
CGriff71's Avatar
CGriff71
4wd Low
You might could say I'm trying to explore all options before I dive in to oil cooler for 1st time.
Old Jul 19, 2022 | 09:59 PM
blicharski1989's Avatar
blicharski1989
that seems a little hot on the oil unless your towing. Today in 100f ambient I saw 194-196 ECT and around 198-200f
Old Jul 21, 2022 | 11:10 AM
HydroTek's Avatar
HydroTek
Flush the system before you put in the new cooler -- that way the junk is already out and does not plug the new cooler
May also want to try a back flush to buy a little more time on the old cooler -- but flush the system first
Gothere
Jan 28, 2017 08:53 AM
rokinfarmer
Jul 18, 2012 04:16 PM
gomfrddy
Jun 25, 2009 07:05 AM
