Has anybody had this happen ?
Excursion V10.
I recently had my freon recharged and now it works when driving.
However, while towing the camper last weekend the blower would be very weak or not blow much at all and the air was accordingly cold but barely coming out.
After un-hitching and driving the air conditioning worked fine again.
We have a 4000# Rockwood 2109S that has the fridge running on the trailer battery when towing.
I am guessing the alternator of the truck somehow can't keep up ?
Am I onto something here or do you have a better idea ?
My guess is that you have a vacuum leak. That will cause the air to blow out of the defroster vents instead of the dash vents, or some partial mix of both.
What type of battery do you have in the trailer? Is it LiFePO4? If so and the battery has a low state of charge it can suck the living daylights out of your alternator. But it shouldn't be able to pull any more amps than the fuse in the 7-pin circuit allows.
A DC-DC charger that is rated for ~20 amps will help reduce the hit on the alternator.
Is your refrigerator a three-way? I've heard that the DC draw can be quite high. I have surplus watts produced by my PV so I run my propane/AC absorption refrigerator off of my inverter. It pulls about 375 watts as I recall.
Not sure about your Ex but on my 96 F150 the AC will discharge out the bottom floor heater discharge duct if the engine is working hard and engine vacuum is low vacuum and discharge will come back to the dash ducts after the vacuum goes high. Obviously the engine is working harder towing a trailer and vacuum will be low.
Just got back from a 600 mile trip, no towing, and air conditioning was fine all the way, so still a mystery why only towing is an issue, but I can live with it I suppose.
Have you looked for a vacuum leak? If there is a leak the air will discharge out of the defrost vents instead of the dash vents. There is less vacuum available from the engine while towing, so this problem will show up only when towing.
I tow over 9,000 pounds with my V10 Excursion and the air works fine.
Excursion V10.
1st do as Mark said and check the vacuum system.
2nd if you are questioning your electrical system get one of these and verify it,
Vents all are good for both air and heat, I suspect vacuum weakness rather than a leak.
The voltmeter you recommend is not an ammeter, but maybe it gives more immediate info on voltage I suppose.
