Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
86 ford F600
Old Jul 6, 2022 | 03:19 PM
7 little peanuts's Avatar
7 little peanuts
1st Gear
86 ford F600
I am looking at a F600 cab and flat bed. The guy selling the truck said it will only do 50 mph. It has a 5 speed manual and a 8.2 diesel motor in it. I asked him if it had a 2 speed rear end in it and he said he didnt think so. So my question is should the truck have a 2 speed rear end and does this seem right for the top speed to only be 50 mhp.
Old Jul 6, 2022 | 08:07 PM
85e150's Avatar
85e150
Welcome to FTE!
An '86 F600 could be had with a single or a two speed. Axle ratios also varied.
If it's geared short, sure, 50 MPH would be it. That engine should be able to bring it up into the 65-70 area easily, IF it's geared for that.
There is a certification label that has the VIN, GVWR, GVAR, and multiple codes on it on the door jamb on those trucks. If you post a picture of it, we can see what it was equipped with.
Gear and transmission changes can be expensive so walk away if you it's not what you want.
Old Jul 7, 2022 | 01:52 PM
fivestarmmd's Avatar
fivestarmmd
My 83 F800 8.2 with 5 and 2 is pretty well done for at 65 mph.
flipper55
Jul 21, 2020 12:49 PM
Alfaromeo
Jul 21, 2011 05:21 PM
bulla
13
Jan 3, 2011 08:53 PM
ajgoggin
15
Jan 20, 2008 10:09 PM
Olds_442
May 11, 2006 10:57 AM
