wheel spacers?
Old Jul 5, 2022 | 08:40 AM
Listor's Avatar
Listor
wheel spacers?
I picked up a set of 1.5" spacers for a set of 18" rims i have, think i may have gotten the wrong set but for 80.00 bucks i figured i could resell them if need be.
I did check them they do fit but seems to have the wrong lug bolts, should i change the studs from the spacer to my hub and vice versa?
Old Jul 5, 2022 | 09:06 AM
brokestroke's Avatar
brokestroke
Sell them and get machined STEEL spacers instead of Aluminum. Those also appear to be lug centric where as the Super Duties are hub centric, that will cause the fitment issue. Proper steel spacers run around $250+/per pair but dont have the risk of splitting in half like the aluminum ones do.
Old Jul 5, 2022 | 09:11 AM
Kwikkordead's Avatar
Kwikkordead
I wouldn't even carry a bale of hay in the bed with aluminum spacers on the truck.
Old Jul 5, 2022 | 10:32 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes, you have the wrong studs and nuts - provided you got 8x170 spacers.
Your pickup will use M14x2.0 (course) studs/nuts and those are M14x1.5 (fine). The easiest way to make those work is to get course lugnuts for the spacers (replace those ones pictured) so they'll bolt to your hubs and then buy fine nuts (04-up) for the wheel side....won't be cheap though.
People always **** on the idea of spacers....I've run a lot of them on a lot of things and have yet to have an issue. The most memorable involved a broken WELD Wheel and the aluminum spacer was just fine.
To each their own.
Old Jul 5, 2022 | 11:11 AM
brokestroke
To each their own.
​​​​​​The correct SD lug nuts on a spacer that is lug centric isn't ideal. Lug centric 8x170 wheels would work with the lug nuts that are on it though.
Old Jul 5, 2022 | 12:31 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Good point. Over the last 20 years I have been used to looking at ones with rings or ones I've machined with rings for the rear.
Old Jul 5, 2022 | 12:44 PM
FordTruckNoob's Avatar
FordTruckNoob
Friends don't let friends use wheel spacers. Get wheels with the correct offset instead.
Old Jul 5, 2022 | 02:25 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
With this comment from Leonard in mind, some sage advice from Rich (Tugly) is in the link below.
Link: https://www.ford-trucks.com/forums/1...eel-specs.html
Old Jul 5, 2022 | 05:02 PM
Dan V's Avatar
Dan V
I ran aluminum spacers....they started their life out 2" but I machined them to 1 3/4". I had them on prior to the axle swap, and I might have had 3k pin weight with a GN horse trailer I was pulling....never had an issue.
greagin
Dec 5, 2018 06:44 AM
Falconater
Mar 19, 2018 09:16 AM
thowle
May 17, 2015 11:40 PM
zstyle01
May 24, 2007 08:11 PM
machipman
Nov 29, 2006 12:51 PM
