Sponsored by: Real Truck
F250 ABS
Old Jun 26, 2022 | 04:46 PM
dandenno's Avatar
dandenno
1st Gear
F250 ABS
I have a 2001 F250 super duty two wheel drive. I just did a brake job on the front, new calipers, new brake lines, turned the discs. The ABS light has been on. I am reinstalling the discs and on the passengers side the square ABS piece is rubbing up against the gear teeth on the inside of the rotor. It sounds like a kid with a playing card in his spokes, I don't know why it is doing that, or if I should be concerned. Would appreciate any insight. Thank you.
Old Jun 26, 2022 | 05:16 PM
manicmechanic007's Avatar
manicmechanic007
Needs a RABS module is my first thought
That is if it is 2 wheel ABS anyway
The speed sensor in the rear axle or the connector is a common issue
You need to check the codes
Old Jun 26, 2022 | 05:18 PM
manicmechanic007
You have the wrong rotor? The abs sensor is not installed correctly?
Kory Bill Popowich
Dec 13, 2016 05:51 AM
prorad
Nov 2, 2011 06:28 PM
tracyclifton
Feb 29, 2008 10:11 PM
ptrnfan
1997 - 2003 F150
Sep 5, 2007 03:05 PM
AllFords1022
Jan 8, 2004 01:50 PM
