Sponsored by: Real Truck
2012 Front Brake Caliper brackets DIY Help... :)
Old Jun 23, 2022 | 07:13 PM
ChiefGeek's Avatar
ChiefGeek
Question 2012 Front Brake Caliper brackets DIY Help... :)
Well, I'm not as good of a mechanic as my dad was, but I'm trying. My dilemma right now is this...I thought I could DIY the front brakes with new rotors and pads but there are a few things I'm still questioning. Hope you guys can help.
  • are the brackets side specific? One has 1133 CMT and the other has 1139 CMT stamped (see pic)
    • Of course, the pins on one of the brackets were seized up and would not come out, even after taking it to a mechanic and having him heat it and beat it, now I need to purchase a new one and the pins, but not sure if (again) they are side specific?
  • Do the brake pads go in AFTER I get the brackets bolted back in place?
  • how do the clips actually go on the pads?
  • is there a website with an expanded picture of these parts showing exactly how they fit?
  • The 2012 brakes are not the same as the 2013 (even though 2012 was supposed to be a new updated model year, but I think are the same as 2011, yes or no?
Thank you all so much in advance.
this was the brake caliper bracket that the pins were seized up in and I need to replace
Old Jun 24, 2022 | 02:29 PM
tired mechanic's Avatar
tired mechanic
8th Gear
I have a 2011 F250 and just put a rebuilt caliper on the right front. I did the left front last year, as they both froze up. The rebuilt caliper comes with the caliper bracket and pins and may be cheaper than buying the bracket new. I do believe they are the same both sides but perhaps others can verify this.
Might try an auto recycler if you just want a used bracket.
I am awaiting backing plates rotors and calipers for the rear as they are all original and the backing plates have rotted out. For my way of thinking it makes sense to do the whole package at this point rather than a piecemeal approach.
Old Jun 24, 2022 | 11:49 PM
WWR's Avatar
WWR
According to listings at RA the brackets are the same.
Put rotor on then bolt bracket in place then install pads. Use a lugnut to hold rotor square if you wish, it can make things easier.
Not sure on the pad hardware without just doing it in person.
'11 was the first year of '11-16. Brakes were upgraded in '13
Old Jun 24, 2022 | 11:54 PM
WWR's Avatar
WWR
Also the Cardone brackets are $20 at RA not including shipping. That does include a $5.40 core charge which is kinda amusing because I don't think you could ship the old one back for that, even using RA's FedEx pricing (which they extend to you on core returns if you want it)
Typically Cardone is sketchy for parts like p/s pumps and racks, but maybe they can't screw up a hunk of metal too much.....hope springs eternal
Old Jun 26, 2022 | 06:25 PM
SnowPlowDriver's Avatar
SnowPlowDriver
I replaced caliper brackets on a 2012 recenly. $20 each side from Oreilly. I had to take one back because the hole for the slide pin was not cleaned out.,poor quality control. 2011 and 12 are the same 2013 and newer different
Elanham59
Sep 23, 2021 11:10 PM
59CRL
Feb 13, 2018 08:18 PM
fordguy2003
Dec 1, 2012 07:41 AM
flatlander757
21
Oct 21, 2011 03:49 PM
pinto21632
Jun 11, 2009 02:37 PM
