Clear coat sanding
Old Jun 25, 2022 | 02:03 PM
unibody62's Avatar
unibody62
Clear coat sanding
I have some clear coat damage on one side of my bed from careless operators at gravel yards. It may be all the way down to the base coat in some areas, but I want to try and sand out what I can. I’m afraid if I leave it it will get worse. Anyways, not sure what grit paper I could safely use. I know I need to work conservatively or I will break through any experience from the members would be helpful.
Old Jun 25, 2022 | 03:53 PM
FuzzFace2's Avatar
FuzzFace2
I am guessing it is chips in the clear coat you have?
With out seeing it but as a guess you will need to sand / feather out the chips most likely down to the base coat (BC).
It the BC has been touched then it will need to be painted and then the CC sprayed on top of that.
Now if you dont touch the BC you will still need to spray CC over it to look right.
I would start with say 600 wet n dry with water and a little Dawn dish soap in the water.
Then move to 1200 and then 1500 and buff.
But again if it has chips you will need to go down pretty far and need to CC again.
What made you think the truck would not get damage at a gravel yard?
Heck I use my F100 for weekly trash runs and as careful as I am the inside of the bed gets scratched from the binds.
Dave ----
Old Jun 25, 2022 | 06:15 PM
unibody62's Avatar
unibody62
Dave ----
Thanks for the reply. Yes lots of chips, but tiny specks really. Too many to try doing each one, so I would sand the whole qtr panel (about 1/2 is affected). If I understand you correctly, I could just reapply clear coat as long as it’s not into the base.
As far as trusting the gravel yard, they are usually pretty careful because they can see it’s a clean 13 YO truck. It’s not like I get gravel everyday, I figured a few loads wouldn’t hurt it. I’ve gotten lots of mulch (not the same, I know). Guess I was wrong. If I need more, I’d probably drape the bedsides with something.
erniesshop
Aug 8, 2010 11:40 PM
Rebel Warrior
Paint & Bodywork
May 7, 2009 10:08 PM
FE352
Paint & Bodywork
Dec 5, 2008 12:05 AM
FordPickMeUp
Paint & Bodywork
Jun 27, 2008 01:56 PM
cid
Paint & Bodywork
13
May 18, 2003 04:57 PM
