what removes primer?
Old Jun 26, 2008 | 08:13 PM
FordPickMeUp's Avatar
FordPickMeUp
my pickup has some primer spray that dryed to bed of my pickup and i cant get it off the paint.I have tryed just about everything i cant seem to get it off is there anything that removes primer off paint at all?
Old Jun 26, 2008 | 08:34 PM
just-n-time's Avatar
just-n-time
Is this a freshly painted truck? If not and some how you got primmer from a rattle can on it or another object was being painted and mist got to it? I cant figure how you had this happen but, if you use a chemical harsh enough (like toluene) you are just as likely to damage you c/c or paint. try a very small area and use white compound see if it will move it, If so then work it out,remember that you do not want to get to aggressive and remove the clear. After you finish use a 3m compound and bring the gloss back up.
Old Jun 27, 2008 | 01:56 PM
e-tek's Avatar
e-tek
Buff it off starting with a cut cmpd, moving to a fine, then glaze. You may need a BS to do it.
jvmcc
Paint & Bodywork
Sep 13, 2013 10:07 PM
rmalottwtes30
Paint & Bodywork
Aug 1, 2005 12:24 AM
Green Streak
Paint & Bodywork
May 1, 2005 10:45 AM
ibanez13547
Paint & Bodywork
Jun 22, 2004 07:37 AM
eb151000
Paint & Bodywork
Jul 24, 2003 05:49 AM
